buonasera,
sto avendo problemi di compilazione con arduino ide, cerco di scaricare il firmware come ho sempre fatto(mkduo) ma mi da questi errori, idee?
grazie in anticipo
ATTENZIONE: la libreria U8glib dichiara di funzionare sulle architetture avr, sam e potrebbe non essere compatibile con la tua scheda che utilizza l'architettura stm32
Generating function prototypes...
"C:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\tools\\xpack-arm-none-eabi-gcc\\9.2.1-1.1/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -mthumb "@C:\\Users\\DMALAT~1\\AppData\\Local\\Temp\\arduino_build_826055/sketch/build_opt.h" -c -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -fno-use-cxa-atexit "-IC:\\Users\\dmalatesta\\Desktop\\stampante acciaio firmware\\MK4duo" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.8.0\\cores\\arduino/avr" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.8.0\\cores\\arduino/stm32" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.8.0\\cores\\arduino/stm32/LL" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.8.0\\cores\\arduino/stm32/usb" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.8.0\\cores\\arduino/stm32/usb/hid" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.8.0\\cores\\arduino/stm32/usb/cdc" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.8.0\\system/Drivers/STM32F4xx_HAL_Driver/Inc" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.8.0\\system/Drivers/STM32F4xx_HAL_Driver/Src" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.8.0\\system/STM32F4xx" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.8.0\\system/Middlewares/ST/STM32_USB_Device_Library/Core/Inc" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.8.0\\system/Middlewares/ST/STM32_USB_Device_Library/Core/Src" -w -x c++ -E -CC -DSTM32F4xx -DARDUINO=10812 -DARDUINO_RUMBA32_F446VE -DARDUINO_ARCH_STM32 "-DBOARD_NAME=\"RUMBA32_F446VE\"" -DSTM32F446xx -DUSBCON -DUSBD_VID=0x0483 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"RUMBA32_F446VE\"" -DHAL_PCD_MODULE_ENABLED -DUSBD_USE_CDC -DHAL_UART_MODULE_ENABLED "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\tools\\CMSIS\\5.5.1/CMSIS/Core/Include/" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.8.0\\system/Drivers/CMSIS/Device/ST/STM32F4xx/Include/" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.8.0\\system/Drivers/CMSIS/Device/ST/STM32F4xx/Source/Templates/gcc/" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\tools\\CMSIS\\5.5.1/CMSIS/DSP/Include" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.8.0\\cores\\arduino" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.8.0\\variants\\RUMBA32_F446VE" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.8.0\\libraries\\SPI\\src" "-IC:\\Users\\dmalatesta\\Documents\\Arduino\\libraries\\SdFat\\src" "-IC:\\Users\\dmalatesta\\Documents\\Arduino\\libraries\\U8glib\\src" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.8.0\\libraries\\SrcWrapper\\src" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.8.0\\libraries\\Wire\\src" "-IC:\\Users\\dmalatesta\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.8.0\\libraries\\EEPROM\\src" "C:\\Users\\DMALAT~1\\AppData\\Local\\Temp\\arduino_build_826055\\sketch\\MK4duo.ino.cpp" -o "C:\\Users\\DMALAT~1\\AppData\\Local\\Temp\\arduino_build_826055\\preproc\\ctags_target_for_gcc_minus_e.cpp"
In file included from C:\Users\DMALAT~1\AppData\Local\Temp\arduino_build_826055\sketch\MK4duo.h:116,
                 from C:\Users\dmalatesta\Desktop\stampante acciaio firmware\MK4duo\MK4duo.ino:359:
C:\Users\DMALAT~1\AppData\Local\Temp\arduino_build_826055\sketch\src/platform/platform.h:58:6: error: #error "DEPENDENCY ERROR: Please download last version of STM32_CORE"
   58 |     #error "DEPENDENCY ERROR: Please download last version of STM32_CORE"
Più di una libreria trovata per "SdFat.h"
Usata: C:\Users\dmalatesta\Documents\Arduino\libraries\SdFat
Non usata: C:\Program Files (x86)\Arduino\libraries\SdFat-master
Non usata: C:\Users\dmalatesta\Documents\Arduino\libraries\SdFat_-_Adafruit_Fork
Uso la libreria SPI alla versione 1.0 nella cartella: C:\Users\dmalatesta\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.8.0\libraries\SPI
Uso la libreria SdFat alla versione 1.1.2 nella cartella: C:\Users\dmalatesta\Documents\Arduino\libraries\SdFat
Uso la libreria U8glib alla versione 1.19.1 nella cartella: C:\Users\dmalatesta\Documents\Arduino\libraries\U8glib
Uso la libreria SrcWrapper alla versione 1.0.1 nella cartella: C:\Users\dmalatesta\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.8.0\libraries\SrcWrapper
Uso la libreria Wire alla versione 1.0 nella cartella: C:\Users\dmalatesta\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.8.0\libraries\Wire
Uso la libreria EEPROM alla versione 2.0.1 nella cartella: C:\Users\dmalatesta\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.8.0\libraries\EEPROM
exit status 1
Errore durante la compilazione per la scheda 3D printer boards.
Trovata libreria non valida in C:\Program Files (x86)\Arduino\libraries\Arduino_Core_STM32-master: Nessun header file (.h) trovato in C:\Program Files (x86)\Arduino\libraries\Arduino_Core_STM32-master
55 minuti fa, zed87 dice:
secondo me il problema è qua' sotto (prima riga degli errori)
ma in passato lo compilavi senza errori?
ciao, si ho il vecchio firmware che va senza problemi e lo compilo e scarico, la scheda è una rumba32.
il monitor è il solito, un 12864 cinesissimo
14 minuti fa, zed87 dice:
sicuramente è un bug,togli la libreria e prova
29 minuti fa, zed87 dice:
ok provo domani mattina, comunque è strano, se provo a scaricare il vecchio firmware va senza problemi...
a me succede la stessa cosa con un altra scheda,prima andava,poi quando ho deciso di aggiornare dopo circa 1 anno,se abilito la scrittura in eeprom ho un errore..quindi o mi tengo la vecchia versione o la nuova senza poter usare m500
mk4duo è moooolto buggato
ma se stai usando mk4duo ed usi il compilatore online lo compili da zero lo stesso gia di suo
oppure stai usando un mk4duo gia fatto? se si abbandonalo ed aggiorna le librerie di arduino installate e ricompila dal compilatore online
