Samu90 Inviato 17 Novembre 2020 Inviato 17 Novembre 2020 Hello, I'm new to the forum. I installed version 1.1.9 Marlin on a Creality cr-10. My problem is that when the machine finishes printing, the Y axis is positioned opposite to how it was positioned before.Having already built a wooden enclosure, the Y axis directed in the front position hits the door.If I send to Auto Home from the LCD display the direction has remained unchanged since before the update and therefore it goes to the back position, which would be the position that should also go at the end of the print. How can I change the direction of the Y axis in the firmware only for automatic positioning at the end of printing?I thank everyone in advance. Samuel Cita
Killrob Inviato 17 Novembre 2020 Inviato 17 Novembre 2020 Hi Samuel, which slicer you use? Cura? if so, post here the end-gcode pls Cita
Samu90 Inviato 18 Novembre 2020 Autore Inviato 18 Novembre 2020 Hi! yes I use Cura. Where can I find the end-gcode pls? After the update, by the way, I am no longer able to control the printer via Cura. And to print I'm just using the SD card. Cita
Killrob Inviato 18 Novembre 2020 Inviato 18 Novembre 2020 8 ore fa, Samu90 dice: Hi! yes I use Cura. Where can I find the end-gcode pls? After the update, by the way, I am no longer able to control the printer via Cura. And to print I'm just using the SD card. you can find it here: Settings->printer->manage printers then click on machine settings Cita
Samu90 Inviato 19 Novembre 2020 Autore Inviato 19 Novembre 2020 CODE G START: M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk M220 S100 ;Reset Feedrate M221 S100 ;Reset Flowrate G28 ;Home G92 E0 ;Reset Extruder G1 Z2.0 F3000 ;Move Z Axis up G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line G92 E0 ;Reset Extruder G1 Z2.0 F3000 ;Move Z Axis up CODE G END: G91 ;Relative positioning G1 E-2 F2700 ;Retract a bit G1 E-2 Z0.2 F2400 ;Retract and raise Z G1 X5 Y5 F3000 ;Wipe out G1 Z10 ;Raise Z more G90 ;Absolute positionning G1 X0 Y{machine_depth} ;Present print M106 S0 ;Turn-off fan M104 S0 ;Turn-off hotend M140 S0 ;Turn-off bed M84 X Y E ;Disable all steppers but Z Cita
Killrob Inviato 19 Novembre 2020 Inviato 19 Novembre 2020 Ok if you want home you can replace this G1 X0 Y{machine_depth} ;Present print With G28 In end-gcode In this way at the end of the print your hotend go home 1 Cita
Samu90 Inviato 19 Novembre 2020 Autore Inviato 19 Novembre 2020 It was just like you said. I spent an hour trying to change the firmware, but it really had nothing to do with it. Thanks a lot, you saved me a lot of more time! Cita
Killrob Inviato 19 Novembre 2020 Inviato 19 Novembre 2020 3 ore fa, Samu90 dice: It was just like you said. I spent an hour trying to change the firmware, but it really had nothing to do with it. Thanks a lot, you saved me a lot of more time! your welcome 😉 Cita
