suunto69 Inviato 5 Gennaio 2022 Inviato 5 Gennaio 2022 ho una ender3 v2, la collego con Repetier-Host ma non mi da il parametro M92 19:36:15.725 : OpenGL renderer:NVIDIA GeForce GTX 970/PCIe/SSE2 19:36:15.725 : Using fast VBOs for rendering is possible 19:36:21.429 : No start signal detected - forcing start 19:36:21.461 : N1 M110*34 19:36:21.461 : N2 M115*36 19:36:21.461 : N3 M105*36 19:36:21.461 : N4 M114*35 19:36:21.461 : N5 M111 S6*98 19:36:21.462 : N6 T0*60 19:36:21.462 : N7 M20*22 19:36:21.462 : N8 M80*19 19:36:24.562 : N9 M105*46 19:36:27.670 : N10 M105*22 19:36:27.674 : echo:Unknown command: "?" 19:36:30.748 : N11 M105*23 19:36:33.825 : N12 M105*20 19:36:36.828 : N13 M105*21 19:36:36.832 : echo:Unknown command: "" 19:36:39.917 : N14 M105*18 19:36:43.014 : N15 M105*19 19:36:46.023 : N16 M105*16 19:36:49.026 : N17 M105*17 19:36:52.119 : N18 M105*30 19:36:55.226 : N19 M105*31 19:37:35.325 : Communication timeout - reset send buffer block 19:37:35.325 : N20 M105*21 19:37:35.330 : echo:Unknown command: "" 19:37:38.300 : N21 M105*20 19:37:41.399 : N22 M105*23 19:37:44.500 : N23 M105*22 19:37:47.501 : N24 M105*17 19:37:50.585 : N25 M105*16 19:37:53.647 : N26 M105*19 19:37:56.731 : N27 M105*18 19:37:59.736 : N28 M105*29 19:38:02.845 : N29 M105*28 19:38:02.849 : echo:Unknown command: "?" 19:38:05.937 : N30 M105*20 19:38:09.031 : N31 M105*21 19:38:12.106 : N32 M105*22 19:38:12.111 : echo:Unknown command: "R?" 19:38:15.174 : N33 M105*23 19:38:18.279 : N34 M105*16 19:38:21.388 : N35 M105*17 19:38:24.493 : N36 M105*18 19:38:27.586 : N37 M105*19 19:38:30.598 : N38 M105*28 19:38:33.695 : N39 M105*29 19:38:36.789 : N40 M105*19 19:39:16.838 : Communication timeout - reset send buffer block 19:39:16.838 : N41 M105*18 19:39:16.843 : echo:Unknown command: "[?" 19:39:16.950 : N42 M105*17 19:39:20.062 : N43 M105*16 19:39:23.137 : N44 M105*23 19:39:26.229 : N45 M105*22 19:39:29.337 : N46 M105*21 19:39:32.440 : N47 M105*20 19:39:35.450 : N48 M105*27 19:39:38.548 : N49 M105*26 19:39:41.631 : N50 M105*18 19:39:44.726 : N51 M105*19 come faccio a calibrare gli assi? grazie Cita
Killrob Inviato 5 Gennaio 2022 Inviato 5 Gennaio 2022 non mi sembra affatto collegata la stampante Il 05/01/2022 at 18:41, suunto69 ha scritto: 19:39:16.838 : Communication timeout - reset send buffer block Expand i drivers li hai installati? Cita
suunto69 Inviato 5 Gennaio 2022 Autore Inviato 5 Gennaio 2022 si anche perchè io con il pc mi collego alla stampante Cita
Killrob Inviato 5 Gennaio 2022 Inviato 5 Gennaio 2022 ma a repetier host in quest caso non è collegata e te lo dice anche qui: Il 05/01/2022 at 18:41, suunto69 ha scritto: 19:36:21.429 : No start signal detected - forcing start Expand se cerchi di far partire repetier host con Cura aperto... Cura ha il brutto vizio di occupare la porta USB anche se non la sta usando. Cita
suunto69 Inviato 5 Gennaio 2022 Autore Inviato 5 Gennaio 2022 (aggiornato) 19:48:21.347 : OpenGL renderer:NVIDIA GeForce GTX 970/PCIe/SSE2 19:48:21.347 : Using fast VBOs for rendering is possible 19:48:35.520 : No start signal detected - forcing start 19:48:35.549 : N1 M110*34 19:48:35.549 : N2 M115*36 19:48:35.549 : N3 M105*36 19:48:35.549 : N4 M114*35 19:48:35.549 : N5 M111 S6*98 19:48:35.549 : N6 T0*60 19:48:35.549 : N7 M20*22 19:48:35.549 : N8 M80*19 19:48:38.621 : N9 M105*46 19:48:41.629 : N10 M105*22 19:48:41.634 : echo:Unknown command: "?" 19:48:44.637 : N11 M105*23 19:48:47.747 : N12 M105*20 19:48:50.854 : N13 M105*21 19:48:50.858 : echo:Unknown command: "" 19:48:53.962 : N14 M105*18 come mai con Simplify3d mi collego? Verifica del protocollo di comunicazione in testo semplice... LETTI: echo:Unknown command: "" LETTI: ok Sei collegato alla macchina! INVIATI: T0 LETTI: ok INVIATI: M105 LETTI: ok T:23.12 /0.00 B:30.42 /0.00 @:0 B@:0 INVIATI: M105 LETTI: ok T:23.12 /0.00 B:30.42 /0.00 @:0 B@:0 INVIATI: M105 LETTI: ok T:23.12 /0.00 B:30.42 /0.00 @:0 B@:0 INVIATI: M105 LETTI: ok T:23.12 /0.00 B:30.42 /0.00 @:0 B@:0 INVIATI: M105 LETTI: ok T:23.12 /0.00 B:30.39 /0.00 @:0 B@:0 INVIATI: M105 LETTI: ok T:23.12 /0.00 B:30.39 /0.00 @:0 B@:0 INVIATI: M105 LETTI: ok T:23.12 /0.00 B:30.29 /0.00 @:0 B@:0 INVIATI: M105 LETTI: ok T:23.16 /0.00 B:30.23 /0.00 @:0 B@:0 INVIATI: M105 LETTI: ok T:23.12 /0.00 B:30.18 /0.00 @:0 B@:0 INVIATI: M105 LETTI: ok T:23.12 /0.00 B:30.16 /0.00 @:0 B@:0 INVIATI: M105 LETTI: ok T:23.12 /0.00 B:30.08 /0.00 @:0 B@:0 INVIATI: M105 LETTI: ok T:23.12 /0.00 B:30.00 /0.00 @:0 B@:0 Modificato 5 Gennaio 2022 da Killrob post troppo lungo Cita
FoNzY Inviato 5 Gennaio 2022 Inviato 5 Gennaio 2022 Il 05/01/2022 at 18:51, suunto69 ha scritto: come mai con Simplify3d mi collego? Expand sbagli qualche impostazione su repetier comunque puoi capire il numero di step\mm guardando alla meccanica e puoi star certo che il valore impostato è quello che risulta dalla divisione "perfetta" 200 step\mm per X/Y e 400 per Z Cita
suunto69 Inviato 6 Gennaio 2022 Autore Inviato 6 Gennaio 2022 ciao, tu hai scritto "comunque puoi capire il numero di step\mm guardando alla meccanica" come? Cita
suunto69 Inviato 6 Gennaio 2022 Autore Inviato 6 Gennaio 2022 sono riuscito a collegare la stampante con Repetier-Host ma nel log non mi fa vedere il comando M92 09:17:20.368 : FIRMWARE_NAME:Marlin Ver 1.0.2 SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Ender-3 V2 EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff 09:17:20.368 : Cap:SERIAL_XON_XOFF:0 09:17:20.368 : N9 M220 S100*104 09:17:20.368 : N10 M221 S100*81 09:17:20.370 : Cap:BINARY_FILE_TRANSFER:0 09:17:20.373 : Cap:EEPROM:1 09:17:20.373 : Cap:VOLUMETRIC:1 09:17:20.376 : Cap:AUTOREPORT_TEMP:1 09:17:20.376 : Cap:PROGRESS:0 09:17:20.378 : Cap:PRINT_JOB:1 09:17:20.378 : Cap:AUTOLEVEL:0 09:17:20.381 : Cap:Z_PROBE:0 09:17:20.384 : Cap:LEVELING_DATA:0 09:17:20.384 : Cap:BUILD_PERCENT:0 09:17:20.387 : Cap:SOFTWARE_POWER:0 09:17:20.389 : Cap:TOGGLE_LIGHTS:0 09:17:20.389 : Cap:CASE_LIGHT_BRIGHTNESS:0 09:17:20.392 : Cap:EMERGENCY_PARSER:0 09:17:20.395 : Cap:PROMPT_SUPPORT:0 09:17:20.398 : Cap:AUTOREPORT_SD_STATUS:0 09:17:20.401 : Cap:THERMAL_PROTECTION:1 09:17:20.401 : Cap:MOTION_MODES:0 09:17:20.403 : Cap:CHAMBER_TEMPERATURE:0 09:17:20.403 : N11 M111 S6*87 09:17:20.409 : Error:Line Number is not Last Line Number+1, Last Line: 2 09:17:20.409 : Resend: 3 09:17:20.427 : Resend: N3 M105*36 09:17:20.427 : Resend: N4 M114*35 09:17:20.427 : Resend: N5 M111 S6*98 09:17:20.427 : Resend: N6 T0*60 09:17:20.427 : Resend: N7 M20*22 09:17:20.427 : Resend: N8 M80*19 09:17:20.427 : Resend: N9 M220 S100*104 09:17:20.427 : Resend: N10 M221 S100*81 09:17:20.427 : Resend: N11 M111 S6*87 09:17:20.427 : echo:Unknown command: "*60" 09:17:20.427 : Error:Line Number is not Last Line Number+1, Last Line: 2 09:17:20.427 : Resend: 3 09:17:20.433 : N12 T0*9 09:17:20.433 : N13 M155 S1*82 09:17:20.443 : Resend: N3 M105*36 09:17:20.443 : Resend: N4 M114*35 09:17:20.443 : Resend: N5 M111 S6*98 09:17:20.443 : Resend: N6 T0*60 09:17:20.443 : Resend: N7 M20*22 09:17:20.443 : Resend: N8 M80*19 09:17:20.443 : Resend: N9 M220 S100*104 09:17:20.443 : Resend: N10 M221 S100*81 09:17:20.443 : Resend: N11 M111 S6*87 09:17:20.443 : Resend: N12 T0*9 09:17:20.464 : Resend: N13 M155 S1*82 09:17:20.464 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0 09:17:20.464 : echo:DEBUG:INFO,ERRORS 09:17:20.465 : Begin file list 09:17:20.466 : DIS_1~1.GCO 9808328 09:17:20.466 : REMIX_~1.GCO 954815 09:17:20.466 : HOMEMA~1.GCO 5110465 09:17:20.466 : 3DBENC~1.GCO 2512498 09:17:20.466 : PROVAL~1.GCO 43843 09:17:20.466 : PATHFI~1.GCO 6996751 09:17:20.466 : TEST-D~1.GCO 16902719 09:17:20.466 : MYLOWE~1.GCO 2770490 09:17:20.467 : End file list 09:17:20.467 : Error:checksum mismatch, Last Line: 8 09:17:20.467 : Resend: 9 09:17:20.491 : Resend: N9 M220 S100*104 09:17:20.491 : Resend: N10 M221 S100*81 09:17:20.491 : Resend: N11 M111 S6*87 09:17:20.491 : Resend: N12 T0*9 09:17:20.491 : Resend: N13 M155 S1*82 09:17:20.491 : echo:Unknown command: "M80" 09:17:20.491 : Error:Line Number is not Last Line Number+1, Last Line: 8 09:17:20.491 : Resend: 9 09:17:20.507 : Resend: N9 M220 S100*104 09:17:20.507 : Resend: N10 M221 S100*81 09:17:20.507 : Resend: N11 M111 S6*87 09:17:20.507 : Resend: N12 T0*9 09:17:20.507 : Resend: N13 M155 S1*82 09:17:20.507 : echo:DEBUG:INFO,ERRORS 09:17:20.515 : Error:Line Number is not Last Line Number+1, Last Line: 13 09:17:20.517 : Resend: 14 09:17:20.539 : Error:Line Number is not Last Line Number+1, Last Line: 13 09:17:20.539 : Resend: 14 09:17:20.555 : echo:Unknown command: "10 M221 S100" 09:18:08.152 : No start signal detected - forcing start con la prima stampante una Geeetech A10m non avevo propremi, come mai? grazie posso leggere il comando M92 dal display della stampante? Cita
dnasini Inviato 7 Gennaio 2022 Inviato 7 Gennaio 2022 Il 06/01/2022 at 08:32, suunto69 ha scritto: posso leggere il comando M92 dal display della stampante? Expand la risposta veloce e' si, ad ogni modo credo dipenda dalla versione di fw installato. Io attualmente ho montato una 2.0.9.1 e nel menu' ho una voce dove mi viene visualizzato il valore di Step/mm e dove posso modificarlo. Nella versione precedente (se non ricordo male una 1.1.9) questo menu' non lo avevo (come molti altri del resto) ed ero costretto a collegarmi da PC x vederlo ed impostarlo. Cita
