apprendista Inviato 17 Maggio 2024 Autore Inviato 17 Maggio 2024 Ho mandato la richiesta di accesso Cita
Offshore Inviato 17 Maggio 2024 Inviato 17 Maggio 2024 https://drive.google.com/file/d/1zf8HE0rorONKktiaqm1NIkuWpWBvFFI4/view?usp=sharing senza accesso... 1 Cita
Offshore Inviato 17 Maggio 2024 Inviato 17 Maggio 2024 /dev/serial/by-path/platform-ff580000.usb-usb-0:1:1.0-port0 1 Cita
apprendista Inviato 19 Maggio 2024 Autore Inviato 19 Maggio 2024 https://github-com.translate.goog/Sovol3d/SOVOL_KLIPAD50_SYSTEM?_x_tr_sl=en&_x_tr_tl=it&_x_tr_hl=it&_x_tr_pto=sc seguendo questo ho rifatto tutto sulla emmc da 8g sono entrato con il terminale di linus e mi ha dato questo fede@fede-MSI-NOTEBOOK-CR610:~$ sudo ssh mks@192.168.188.191 [sudo] password di fede: The authenticity of host '192.168.188.191 (192.168.188.191)' can't be established. ED25519 key fingerprint is SHA256:coK0VfHvCsgmO5mprF2xdp8KXekTBWaN4GJE3hGGhL4. This key is not known by any other names Are you sure you want to continue connecting (yes/no/[fingerprint])? yes Warning: Permanently added '192.168.188.191' (ED25519) to the list of known hosts. mks@192.168.188.191's password: _ _ _ __ ___ | | _____ _ __ (_) | '_ ` _ \| |/ / __| '_ \| | | | | | | | <\__ \ |_) | | |_| |_| |_|_|\_\___/ .__/|_| |_| Welcome to Armbian 22.05.0-trunk with bleeding edge Linux 5.16.20-rockchip64 No end-user support: built from trunk System load: 2% Up time: 33 min Memory usage: 47% of 976M IP: 192.168.188.191 CPU temp: 74°C Usage of /: 68% of 6.8G RX today: Error: eth0: Invalid database daily date order: 1550141664 (0) < 1679105495 (1) Error: eth0: Invalid database daily date order: 1550140736 (0) < 1679105495 (1) Error: Unable to use database "/var/lib/vnstat/eth0" or backup database "/var/lib/vnstat/.eth0". [ 0 security updates available, 17 updates total: apt upgrade ] Last check: 2023-12-29 03:11 Last login: Tue Jul 18 03:39:58 2023 from 192.168.2.132 mks@mkspi:~$ ls /dev/serial/by-id/* /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0 mks@mkspi:~$ sono entrato in printer .cfg e su serial ho copiato : /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0 ho selezionato salve e riavvia printer.cfg ed ora mi da :mcu 'mcu': Unable to connect Once the underlying issue is corrected, use the "FIRMWARE_RESTART" command to reset the firmware, reload the config, and restart the host software. Error configuring printer syste load da: OS: Armbian 22.05.0-trunk Buster Distro: armbian Load: 0, Mem: 976.4 MB, Temp: 74°C wlan0 (192.168.188.191) : Bandwidth: 2.0 kB/s , Received: 484.5 kB , Transmitted: 7.9 MB Cita
