eaman Inviato 15 Luglio 2024 Inviato 15 Luglio 2024 attacca una periferica usb e fai: 14 minuti fa, apprendista ha scritto: pi@pi:~ $ dmesg | tail Cita
apprendista Inviato 15 Luglio 2024 Autore Inviato 15 Luglio 2024 fede@fede-laptop:~$ dmesg | tail [ 86.007567] [UFW BLOCK] IN=wlp8s0 OUT= MAC= SRC=fe80:0000:0000:0000:7570:ca68:0d26:271c DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=346071 PROTO=UDP SPT=8612 DPT=8612 LEN=24 [ 86.011732] [UFW BLOCK] IN=wlp8s0 OUT= MAC= SRC=fe80:0000:0000:0000:7570:ca68:0d26:271c DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=991805 PROTO=UDP SPT=8612 DPT=8610 LEN=24 [ 87.520582] [UFW BLOCK] IN=wlp8s0 OUT= MAC=01:00:5e:00:00:01:44:4e:6d:e2:6c:d4:08:00 SRC=192.168.178.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=59800 DF PROTO=2 [ 100.832863] [UFW BLOCK] IN=wlp8s0 OUT= MAC=00:13:02:42:34:c0:44:4e:6d:e2:6c:d4:86:dd SRC=fd00:0000:0000:0000:464e:6dff:fee2:6cd4 DST=fd00:0000:0000:0000:efe3:d6df:3d9a:c88e LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=0 PROTO=TCP SPT=59703 DPT=80 WINDOW=28800 RES=0x00 SYN URGP=0 [ 100.833030] [UFW BLOCK] IN=wlp8s0 OUT= MAC=00:13:02:42:34:c0:44:4e:6d:e2:6c:d4:08:00 SRC=192.168.178.1 DST=192.168.178.140 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=25800 DF PROTO=TCP SPT=34697 DPT=80 WINDOW=29200 RES=0x00 SYN URGP=0 [ 132.576892] [UFW BLOCK] IN=wlp8s0 OUT= MAC=00:13:02:42:34:c0:44:4e:6d:e2:6c:d4:08:00 SRC=192.168.178.1 DST=192.168.178.140 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=25801 DF PROTO=TCP SPT=34697 DPT=80 WINDOW=29200 RES=0x00 SYN URGP=0 [ 132.577056] [UFW BLOCK] IN=wlp8s0 OUT= MAC=00:13:02:42:34:c0:44:4e:6d:e2:6c:d4:86:dd SRC=fd00:0000:0000:0000:464e:6dff:fee2:6cd4 DST=fd00:0000:0000:0000:efe3:d6df:3d9a:c88e LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=0 PROTO=TCP SPT=59703 DPT=80 WINDOW=28800 RES=0x00 SYN URGP=0 [ 212.448776] [UFW BLOCK] IN=wlp8s0 OUT= MAC=01:00:5e:00:00:01:44:4e:6d:e2:6c:d4:08:00 SRC=192.168.178.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=61436 DF PROTO=2 [ 337.479376] [UFW BLOCK] IN=wlp8s0 OUT= MAC=01:00:5e:00:00:01:44:4e:6d:e2:6c:d4:08:00 SRC=192.168.178.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=64266 DF PROTO=2 [ 380.282913] [UFW BLOCK] IN=wlp8s0 OUT= MAC=33:33:00:00:00:01:44:4e:6d:e2:6c:d4:86:dd SRC=fe80:0000:0000:0000:464e:6dff:fee2:6cd4 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=UDP SPT=53805 DPT=53805 LEN=24 fede@fede-laptop:~$ Cita
apprendista Inviato 15 Luglio 2024 Autore Inviato 15 Luglio 2024 una volta che mi da quest arisposta al comando ollegando il portatile al raspberry che significato ha ? Cita
eaman Inviato 15 Luglio 2024 Inviato 15 Luglio 2024 cosa il kernel sta facendo con la periferica usb ---------------------- Con una stampante 3d collegata a un host klipper dovresti vedere qualcosa tipo: [112407.567812] ch341 8-1:1.0: ch341-uart converter detected [112407.578998] usb 8-1: ch341-uart converter now attached to ttyUSB1 [112407.710430] usb 6-1: New USB device found, idVendor=1d50, idProduct=614e, bcdDevice= 1.00 [112407.710494] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [112407.710522] usb 6-1: Product: stm32f103xe [112407.710544] usb 6-1: Manufacturer: Klipper [112407.710566] usb 6-1: SerialNumber: 30FFD8053054483126651843 [112407.723767] cdc_acm 6-1:1.0: ttyACM1: USB ACM device 1 Cita
apprendista Inviato 15 Luglio 2024 Autore Inviato 15 Luglio 2024 ma non ha dato una risposta simile credo, giusto ? vuol dire che la porta microusb da corrente ma non passano i dati ? o solamente non viene riconosciuta ? ma se cosi come mai ? Cita
dnasini Inviato 15 Luglio 2024 Inviato 15 Luglio 2024 in soldoni, se hai installato correttamene Klipper su raspi, hai compilato e flashato il fw di Klipper sulla scheda della stampante e raspi e stampante sono correttamente collegati via USB, facendo SSH sul raspi e lanciando il comando ls /dev/serial/by-id/* dovresti ottenere un output simile a questo /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0 Questo risuldato rappresenta il valore che dovrai mettere nel file di config printer.cfg della stampante affinche' Klipper possa dialogare con la tua stampante (https://www.klipper3d.org/FAQ.html#wheres-my-serial-port) Se nn ottieni quanto sopra, una delle due componenti (o entrambe) non sono ben configurate/installate Cita
eaman Inviato 15 Luglio 2024 Inviato 15 Luglio 2024 1 minuto fa, apprendista ha scritto: ma non ha dato una risposta simile credo, giusto ? vuol dire che la porta microusb da corrente ma non passano i dati ? o solamente non viene riconosciuta ? ma se cosi come mai ? Secondo me hai caricato una versione di firmware sbagliata sulla MCU che quindi non funziona. 1 Cita
apprendista Inviato 15 Luglio 2024 Autore Inviato 15 Luglio 2024 allora dovro ricominciare da zero , questa volta credete sia meglio usare raspberry image o no? 1 1 Cita
eaman Inviato 15 Luglio 2024 Inviato 15 Luglio 2024 1 minuto fa, apprendista ha scritto: allora dovro ricominciare da zero , questa volta credete sia meglio usare raspberry image o no? No La rpi abbiamo appena detto che ha il sistema operativo giusto e il kernel giusto DIO BUONO! Cita
