Oraziomax Inviato 13 Agosto 2016 Inviato 13 Agosto 2016 salve gente. volevo chiedervi aiuto sulla mia stampante r2 mi sta facendo sclerare . i motori non vogliono andare fanno solo rumore e vanno a scatti . ho registrato i driver : Y- X -estrusore a 075 v .e Z a 1v. i drive sono dei A4988 . i motori dei nema 17 a 1,7A . il firmware e merlin kimbra per r2 .vi chiedo se mi potete aiutare perche non so cosa spostare ed ho paura di bruciare qualcosa . questi sono i settaggi delle accelerazioni : / MOVEMENT SETTINGS #define HOMING_FEEDRATE {140*60,140*60,3*60,0} // set the homing speeds (mm/min) // default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {160,160,6400,1240,1240,625,625} // X, Y, Z, E0, E1, E2, E3 default steps per unit #define DEFAULT_MAX_FEEDRATE {300,300,4,50,50,100,100} // X, Y, Z, E0, E1, E2, E3 (mm/sec) #define DEFAULT_RETRACTION_MAX_FEEDRATE {100,100,150,150} // E0, E1, E2, E3 (mm/sec) #define DEFAULT_MAX_ACCELERATION {3000,3000,50,3000,3000,3000,3000} // X, Y, Z, E0, E1, E2, E3 maximum start speed for accelerated moves. #define DEFAULT_ACCELERATION 2500 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 5000 // E max acceleration in mm/s^2 for retracts #define DEFAULT_TRAVEL_ACCELERATION 3000 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves // Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing). // The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder). // For the other hotends it is their distance from the extruder 0 hotend. //#define HOTEND_OFFSET_X {0.0, 5.00, 0.0, 0.0} // (in mm) for each extruder, offset of the hotend on the X axis //#define HOTEND_OFFSET_Y {0.0, 5.00, 0.0, 0.0} // (in mm) for each extruder, offset of the hotend on the Y axis // The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously) #define DEFAULT_XYJERK 15 // (mm/sec) #define DEFAULT_ZJERK 0.4 // (mm/sec) #define DEFAULT_EJERK 5 // (mm/sec) Cita
