Il 5/11/2018 at 11:30 AM, 0xdeadbeef ha scritto:
For what it's worth: I had a deeper look into the "ZCodeX" format and to my surprise, I was wrong about ConfigurationData being used for certification, so it doesn't need to be changed for ZCode patching or creation. Actually, the ConfigurationData is just what the name implies: the serialized and encrypted slicer Configuration.
I'm actually not sure why it's part of the ZCodeX archive at all as it only contains information about slicer configuration which neither the printer nor Z-Suite need to print or display the ZCode.
Well, Z-Suite doesn't even complain when the file is totally missing. I would assume it's only there for fault analysis (i.e. people send ZCodeX files to Zortrax to get support) but this doesn't really explain why they spent the additional effort to encrypt the file.
Anyway, even if I'm too lazy right now to add ZCodeX support to my tools, I managed to patch a ZCODEX archive manually to load modified ZCcode into Z-Suite.
So using 3rd party slicers on the m200 Plus seems totally possible and it actually looks like Zortrax didn't even try to block 3rd party ZCode..
Has anyone tried to use the Palette on Zortax?
Is very old topic this one, i doubt that those Users are still online here, there is only one user here that use a Zortrax printer @FoNzY, maybe he can help you
i don't know but i think not....you should ask to "mosaic" if their machine is compatible with zortrax, they will surely tell you if it is...
