jonny Inviato 13 Dicembre 2017 Inviato 13 Dicembre 2017 buongiorno, ho un problema con la stampante 3d fin da quando l' ho comprata, quando la accendo la temperatura dell' estrusore sale continuamente fino a raggiungere il limite e darmi l' errore come posso fare per aggiustarla? ps: collegandola al computer mi da questo: 16:06:42.708 : OpenGL version:1.1.0 16:06:42.708 : OpenGL extensions:GL_WIN_swap_hint GL_EXT_bgra GL_EXT_paletted_texture 16:06:42.708 : OpenGL renderer:GDI Generic 16:06:42.708 : Fast VBOs for rendering not supported. Using slower default method. 16:07:05.629 : No start signal detected - forcing start 16:07:07.941 : Printer reset detected - initalizing 16:07:07.973 : start 16:07:07.973 : echo:PowerUp 16:07:07.973 : External Reset 16:07:07.973 : Brown out Reset 16:07:07.973 : Marlin1.0.0 16:07:07.973 : echo: Last Updated: Apr 6 2017 20:19:33 | Author: (none, default config) 16:07:07.973 : Compiled: Apr 6 2017 16:07:07.973 : echo: Free Memory: 11889 PlannerBufferBytes: 1232 16:07:07.973 : echo:Stored settings retrieved 16:07:10.270 : echo:SD init fail 16:07:10.317 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/ErikZalm/Marlin/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:X3A_8 EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000 16:07:10.348 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00 16:07:10.348 : echo:Active Extruder: 0 16:07:10.348 : Begin file list 16:07:10.348 : End file list 16:07:10.348 : Error:checksum mismatch, Last Line: 1 16:07:10.348 : Resend: 2 16:07:10.379 : Error:Line Number is not Last Line Number+1, Last Line: 1 16:07:10.379 : Resend: 2 16:07:10.395 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/ErikZalm/Marlin/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:X3A_8 EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000 16:07:10.395 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00 16:07:10.410 : echo:Active Extruder: 0 16:07:10.410 : Begin file list 16:07:10.410 : End file list 16:07:10.410 : Error:checksum mismatch, Last Line: 11 16:07:10.426 : Resend: 12 16:07:10.442 : echo:Active Extruder: 0 16:07:10.442 : echo:Active Extruder: 0 16:09:04.791 : Error:Printer halted. kill() called! 16:09:07.385 : No start signal detected - forcing start 16:09:09.729 : Printer reset detected - initalizing 16:09:09.729 : start 16:09:09.729 : echo: External Reset 16:09:09.729 : Marlin1.0.0 16:09:09.729 : echo: Last Updated: Apr 6 2017 20:19:33 | Author: (none, default config) 16:09:09.729 : Compiled: Apr 6 2017 16:09:09.745 : echo: Free Memory: 11889 PlannerBufferBytes: 1232 16:09:09.745 : echo:Stored settings retrieved 16:09:12.042 : echo:SD init fail 16:09:12.089 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/ErikZalm/Marlin/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:X3A_8 EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000 16:09:12.104 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00 16:09:12.104 : echo:Active Extruder: 0 16:09:12.104 : Begin file list 16:09:12.104 : End file list 16:09:12.120 : Error:checksum mismatch, Last Line: 1 16:09:12.120 : Resend: 2 16:09:12.135 : Error:No Line Number with checksum, Last Line: 1 16:09:12.151 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/ErikZalm/Marlin/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:X3A_8 EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000 16:09:12.167 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00 16:09:12.167 : echo:Active Extruder: 0 16:09:12.167 : Begin file list 16:09:12.167 : End file list 16:09:12.182 : Error:checksum mismatch, Last Line: 11 16:09:12.182 : Resend: 12 16:09:12.198 : echo:Active Extruder: 0 16:09:12.198 : echo:Active Extruder: 0 Cita
marcottt Inviato 13 Dicembre 2017 Inviato 13 Dicembre 2017 uhmm ma l'errore a schermo qual'è ? di solito queste cose succedono perchè il sensore di temperatura è scollegato o mal messo... quando l'accendi che temperatura dice ? la mia per esempio indica la temperatura ambiente e di solito è la stessa indicata dal sensore del piatto. quando accendi l'estrusore la temperatura indicata sale ? sale costantemente o sale e scende ? Cita
Alep Inviato 13 Dicembre 2017 Inviato 13 Dicembre 2017 Dal tuo messaggio non è chiaro se la temperatura inizia a salire quando accendi la stampante o quando inizia stampare. Dalla descrizione che fai comunque verrebbe da pensare che ti sale appena la accendi prima ancora di stampare, in questo caso è molto probabile che sia andato in corto (o ci sia finito sopra materiale metallico che faccia da ponte) il mosfet che fa da interruttore e che permette di accendere e spegnere il riscaldamento, Se hai un tester è facile da verificare anche confrontandolo con il mosfet (in genere più grandetto) che controlla il piatto o se hai un secondo estrusore col mosfet del secondo estrusore e se ti da misura notevolmente diverse (in hom) verifichi facilmente se è in corto. Sono componenti in genere grandetti e di facile reperibilità e di basso costo nei negozi di elettronica e se sai saldare a stagno sono di facile sostituzione. I mosfet sono facilmente riconoscibili perchè sono dei transistor in genere grandi intorno ai 4 mm x 4 mm e spesso montano un dissipatore e stanno nelle immediate vicinanze del connettore dei cavi della resistenza dell'estrusore o del piatto, Ce ne sono uno per il piatto (che potrebbe essere leggermente più grande) ed uno per ogni estrusore che puoi montare nella tua stampante. Se hai difficoltà a trovarli basta che posti una foto della tua elettronica e te li indichiamo noi. Un altra eventualità, ma mi sembra molto remota, è che monti un firmware non adatto alla tua elettronica, ma questo mi sembra davvero molto improbabile. Cita
jonny Inviato 13 Dicembre 2017 Autore Inviato 13 Dicembre 2017 La temperatura dell' estrusore comincia a salire appena accendo la stampante e l errore che mi compare quando raggiungo la temperatura massima è "MAXTEMP" Per controllare i transistor devo impostare il tester sulla sezione che uso per vedere se c'è contatto? Cita
Alep Inviato 13 Dicembre 2017 Inviato 13 Dicembre 2017 Esatto, si va bene la sezione per verificare se c'è contatto, provando il mosfet che hai cerchiato e quello affianco a destra dovresti avere un comportamento identico se è tutto sano e diverso se difettoso, prova anche invertendo i cavi del tester. Se guardi bene c'è anche un piedino centrale tagliato , la prova la devi fare tra tutti e tre i piedini compreso il centrale tagliato (poi è saldato nella scheda tramite la testa del mosfet che in foto non si vede) Se il mosfet è bruciato le differenze col mosfet affianco sono clamorose. Cita
jonny Inviato 13 Dicembre 2017 Autore Inviato 13 Dicembre 2017 Il mosfet dell' estrusore da come risultati : 444;0;444(provandolo in tutti i modi tenendo conto anche di quello centrale) mentre quello a fianco da come risultati:1800;0;1800 Quindi è il mosfet da cambiare? Error:checksum mismatch, Last Line: 1 ultima cosa: cosa vuol dire questo errore? Cita
Alep Inviato 13 Dicembre 2017 Inviato 13 Dicembre 2017 Devi scusarmi ma sono stato poco preciso, la misurazione va fatta con almeno un filo che va alla resistenza per connettore staccato o incide troppo sulla misurazione, anche perchè se non ho capito male un mosfet è per il piatto ed uno per la resistenza dell'estrusore e quindi resistenze molto diverse. La misurazione è effettivamente diversa ma o incidono le resistenze del piatto o sarebbe comunque dovuta essere superiore come differenza per giustificare un corto del mosfet. E' vero poi che oltre che andare in corto il mosfet può andare in dispersione che giustificherebbe valori di quel tipo ma è un evento abbastanza raro sopratutto su un componente nuovo per cui lo escluderei. Abbi pazienza rimisura coi cavi staccati e poi vediamo e scusami ancora. Quell'errore è un errore di processo probabilmente riferito ad una comunicazione seriale o a una lettura o scrittura sulla scheda sd. Per verificare che i dati non siano deteriorati si aggiunge alla trasmissione un byte di controllo creato sommando (o con altra funzione matematica) i dati interessati e quindi cosi si può essere certi che non ci sono errori nel trasferimento, La definizione di "errore di checksum" in genere viene utilizzata per segnalare questo tipo di problemi. E' lo stesso concetto utilizzato nel codice fiscale, nell'iban e in tantissimi altri codici dove l'ultimo carattere è proprio il carattere di controllo. 1 Cita
jonny Inviato 17 Dicembre 2017 Autore Inviato 17 Dicembre 2017 Senza collegare le resistenza i risultati sono molto diversi, Chiedevo, che caratteristiche hanno quei mosfet nel senso volt,ampere ecc.. siccome vorrei comprarne alcuni Grazie in anticipo per la risposta Cita
