Ciao a tutti!
Stavo per caricare sulla scheda madre nuova il firmware marlin che avevo preparato ieri e testato da Arduino IDE, senza errori. Dopo aver fatto due piccole modifiche (inserimento dell'UUID della stampante e modifica della X_Min_Pos e Y_Min_Pos), ho effettuato nuovamente, prima di caricare il firmware, una verifica.
Mi è comparso un errore:
Arduino: 1.8.6 (Windows Store 1.8.14.0) (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch\MarlinConfig.h:26:0,
                 from sketch\Sd2Card.cpp:29:
Sd2Card.h:100:39: error: pasting "/* SPI Master In Slave Out pin*/" and "_DDR" does not give a valid preprocessing token
   #define SPI_MISO_PIN MISO_PIN       // SPI Master In Slave Out pin
sketch\fastio.h:94:35: note: in definition of macro '_SET_INPUT'
 #define _SET_INPUT(IO) do {DIO ## IO ## _DDR &= ~_BV(DIO ## IO ## _PIN); } while (0)
sketch\Sd2Card.cpp:316:3: note: in expansion of macro 'SET_INPUT'
   SET_INPUT(SPI_MISO_PIN);
sketch\Sd2Card.cpp:316:13: note: in expansion of macro 'SPI_MISO_PIN'
Sd2Card.h:100:39: error: pasting "/* SPI Master In Slave Out pin*/" and "_PIN" does not give a valid preprocessing token
sketch\fastio.h:94:61: note: in definition of macro '_SET_INPUT'
Sd2Card.h:99:39: error: pasting "/* SPI Master Out Slave In pin*/" and "_DDR" does not give a valid preprocessing token
   #define SPI_MOSI_PIN MOSI_PIN       // SPI Master Out Slave In pin
sketch\fastio.h:95:36: note: in definition of macro '_SET_OUTPUT'
 #define _SET_OUTPUT(IO) do {DIO ## IO ## _DDR |= _BV(DIO ## IO ## _PIN); } while (0)
sketch\Sd2Card.cpp:317:3: note: in expansion of macro 'SET_OUTPUT'
   SET_OUTPUT(SPI_MOSI_PIN);
sketch\Sd2Card.cpp:317:14: note: in expansion of macro 'SPI_MOSI_PIN'
Sd2Card.h:99:39: error: pasting "/* SPI Master Out Slave In pin*/" and "_PIN" does not give a valid preprocessing token
sketch\fastio.h:95:61: note: in definition of macro '_SET_OUTPUT'
Sd2Card.h:101:39: error: pasting "/* SPI Clock pin*/" and "_DDR" does not give a valid preprocessing token
   #define SPI_SCK_PIN SCK_PIN         // SPI Clock pin
sketch\Sd2Card.cpp:318:3: note: in expansion of macro 'SET_OUTPUT'
   SET_OUTPUT(SPI_SCK_PIN);
sketch\Sd2Card.cpp:318:14: note: in expansion of macro 'SPI_SCK_PIN'
Sd2Card.h:101:39: error: pasting "/* SPI Clock pin*/" and "_PIN" does not give a valid preprocessing token
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Sapreste aiutarmi?
11 ore fa, albemasci dice:
Sapreste aiutarmi?
so di persone che hanno il tuo stesso errore anche con firmware appena scaricati e non modificiati,quindi non si tratta di un errore di compilazione, per quanto ne so questo errore è dato da un bug nel sistema di compilazione di arduino che è stato cambiato con uno nuovo ma che è ancora in fase di sviluppo.
prova a scaricare una vecchia versione dell'ide arduino....
