Tomto Inviato 26 Maggio 2019 Inviato 26 Maggio 2019 Il 25/05/2019 at 20:13, iLMario ha scritto: @Tomto neanche provarci, non si può usare il Klipper con i TMC2208 in standalone. La cinematica del Klipper fa andare in blocco i TMC in mezzo alla stampa, per via del StealthChop2 https://github.com/KevinOConnor/klipper/issues/196 https://github.com/KevinOConnor/klipper/blob/master/docs/FAQ.md#my-tmc-motor-driver-turns-off-in-the-middle-of-a-print Expand in pratica si legge: In the above picture, if Klipper is requested to move along the red line and if each black line represents the nominal location to step a stepper, then in the middle of that movement Klipper will arrange to take a step, change the step direction, and then step back. Klipper can perform this step, direction change, and step back in a very small amount of time. It is our current understanding that the TMC2208 and TMC2224 will react poorly to this when they are in "stealthchop" mode. (It is not believed any other TMC drivers are impacted.) It is believed that when the driver sees the two step requests in a small time frame that it dramatically increases current in anticipation of high acceleration. That high current can trip the driver's internal "over current" detection which causes the driver to disable itself. This pattern of steps can occur on all stepper motors and on all robot kinematics. The TMC2208 and TMC2224 do work well with Klipper when run-time configuration mode is used (that is, when a wire is routed from the micro-controller to the PDN-UART pin and the printer config file has a corresponding [tmc2208] config section). When using run-time configuration, either configure the drivers to use "spreadcycle mode" or configure them to use "stealthchop mode" with a reasonable "stealthchop threshold". If one wishes to exclusively use "stealthchop" mode with run-time UART configuration then make sure the stealthchop_threshold is no more than about 10% greater than the maximum velocity of the given axis. It is speculated that with a reasonable stealthchop threshold, then if Klipper sends a "step, direction change, step back" sequence, the driver will briefly transition from stealthchop mode, to spreadcycle mode, and back to stealthchop mode, which should be harmless. Sottolineo che però i 2208 e 2204 utilizzano lo stealthchop2 Gli altri TMC lo stealthchop "1". Comunque in uart i problema scompare. (entro certi limiti). In pratica come ti trovi con klipper visto che stai usando i 2208 in standalone? Cita
iLMario Inviato 26 Maggio 2019 Autore Inviato 26 Maggio 2019 Il 26/05/2019 at 09:53, Tomto ha scritto: in pratica come ti trovi con klipper visto che stai usando i 2208 in standalone? Expand Ho fatto stampe troppo corte per poter giudicare Per ora ho rimesso il Marlin Cita
Tomto Inviato 26 Maggio 2019 Inviato 26 Maggio 2019 Il 26/05/2019 at 09:55, iLMario ha scritto: Ho fatto stampe troppo corte per poter giudicare Per ora ho rimesso il Marlin Expand Ok. Cita
iLMario Inviato 26 Maggio 2019 Autore Inviato 26 Maggio 2019 Il 26/05/2019 at 09:56, Tomto ha scritto: Ok. Expand Comunque appena sistemo i problemi di estrusione approfondisco la questione dei TMC e metto il klipper, funziona meglio con octoprint Il 26/05/2019 at 09:56, Tomto ha scritto: Ok. Expand Comunque appena sistemo i problemi di estrusione approfondisco la questione dei TMC e metto il klipper, funziona meglio con octoprint 1 Cita
iLMario Inviato 26 Maggio 2019 Autore Inviato 26 Maggio 2019 Mi sto per arrendere.... Tre estrusori tutti e 3 rotti allo stesso modo dopo una manciata di stampe: si spacca l'adattatore del bowden, non fa presa sul tubo. Ne ho stampati due, non vanno bene, gli estrusori non riescono a caricare il filo, forse si incastra nel pezzo stampato Il fysetc ci riesce ma lui ha troppo gioco con gli ingranaggi, ci manca poco che clicchi anche da fermo. Cita
Tomto Inviato 26 Maggio 2019 Inviato 26 Maggio 2019 Il 26/05/2019 at 13:39, iLMario ha scritto: si spacca l'adattatore del bowden, non fa presa sul tubo. Ne ho stampati due, non vanno bene, Expand Ma scusa ne Redex non è in metallo? Cita
iLMario Inviato 26 Maggio 2019 Autore Inviato 26 Maggio 2019 Il 26/05/2019 at 13:52, Tomto ha scritto: Ma scusa ne Redex non è in metallo? Expand Si, ma ha solo 4 denti, non è un prenumatico classico. Si spaccano i denti dentro, oppure si allargano e si fila il tubo. Ho stampato questi, sono venuti benone: https://www.thingiverse.com/thing:2838725 ma non funzionano. Vedo ora, però, che il tubo va fatto "passante". Boh, io l'ho infilato tutto fino in fondo, più in su di così non sale. Cita
Tomto Inviato 26 Maggio 2019 Inviato 26 Maggio 2019 Il 26/05/2019 at 14:04, iLMario ha scritto: Vedo ora, però, che il tubo va fatto "passante". Boh, io l'ho infilato tutto fino in fondo, più in su di così non sale. Expand Eh si! altrimenti quando ritrae il filament, si "torce all'interno dell'estrusore. Cita
marcottt Inviato 26 Maggio 2019 Inviato 26 Maggio 2019 Il 26/05/2019 at 14:04, iLMario ha scritto: Si, ma ha solo 4 denti, non è un prenumatico classico. Si spaccano i denti dentro, oppure si allargano e si fila il tubo. Ho stampato questi, sono venuti benone: https://www.thingiverse.com/thing:2838725 ma non funzionano. Vedo ora, però, che il tubo va fatto "passante". Boh, io l'ho infilato tutto fino in fondo, più in su di così non sale.Io lo sto usando con il bmg. Da quando ho messo marlin 1.1.9 si comporta bene (basta stare sotto i 60 mm/s).Anycubic kossel linear plus,Inviato dal mio SM-G935F utilizzando Tapatalk Cita
iLMario Inviato 26 Maggio 2019 Autore Inviato 26 Maggio 2019 Il 26/05/2019 at 15:10, Marcottt ha scritto: Io lo sto usando con il bmg. Da quando ho messo marlin 1.1.9 si comporta bene (basta stare sotto i 60 mm/s). Anycubic kossel linear plus, Inviato dal mio SM-G935F utilizzando Tapatalk Expand Stai usando l'adattatore che ho indicato? Per essere è fatto bene, ho avvitato fino in fondo il connettore pneumatico (grazie al PLA+) e tiene bene. Probabilmente l'ho messo male dentro l'estrusore (o forse non ho messo bene il tubo Cita
