3d-beppe Inviato 21 Gennaio 2015 Inviato 21 Gennaio 2015 Vendo questa stupenda stampante Rostock Mini Pro con nozzle da 0.2mm appena assemblata, fornisco con Bobina da 1Kg di PLA arancio fluo e porta bobina in plexiglass.Fornisco su richiesta foto della stampante e degli oggetti che ho stampato per la calibrazione.Per qualsiasi domanda contattatemi senza problemi anche a info@3d-beppe.comPrezzo 590,00€ trattabili.Seguono caratteristiche:Rostock Mini is a delta 3D Printer originally designed by Bwevans, with smaller build volume compared to a Rostock or Kossel, but much more compact, portable, and desktop friendly. 3dprinterczar improved Rostock mini with carbon fibre arms, Traxxas 5347 u-joints, and a planetary gearbox extruder. The top and bottom plates are made from 6mm acrylic sheet to give strong support of the entire frame. This is a complete kit that contains everything (including tools) to build a Rosotck Mini Pro. The mechanical part can be finished between 3-6 hours depending on your experience with RepRap machines.Technical DetailsBuild Volume: 18cm x 18cm x 20cm cylinderHeatbed: No (PLA is the recommmended filament).Extruder: Bowden extruderElectricalAny RepRap controller supporting 4 steppers and an extruder.12V 10A laptop power chargerNema 17 motors with 0.55 N*m torque x 3Nema 17 motor coupled with a planetary gearboxJ-head MKIV hotend 0,2mmDisplay: 3.0" 2004 LCDVariousForming the largest size: D(Diameter)170mm* H(High)205mmVertical print speed: 100cm³/hForming accuracy: XY:0.012mm, Z:0.004mmLayer thickness: 0.05mm-0.4mmOffline Print (SD Card): SupportDevice size: 300mm*300mm*550mmDevice weight: 4.2 KG Cita
