xxREVENGExx Inviato 9 Dicembre 2019 Inviato 9 Dicembre 2019 Buonasera avevo aperto già una discussione relativi a problemi con questa stampante, prima stampava solamente male, ora non riesce proprio a stampare, è una TRONXY P802MA CON SENSORE, Tramite repetier host vedo alcuni errori nei LOG, ho appena reinstallato repetierhost ho fatto la connessione e mi dice cosi, ho evidenziato gli errori. 20:50:38.054 : start 20:50:38.054 : echo: External Reset 20:50:38.054 : Marlin1.0.0 20:50:38.054 : echo: Last Updated: Apr 7 2017 19:32:27 | Author: (none, default config) 20:50:38.054 : Compiled: Apr 7 2017 20:50:38.054 : echo: Free Memory: 11889 PlannerBufferBytes: 1232 20:50:38.056 : echo:Stored settings retrieved 20:50:38.371 : Error:volume.init failed 20:50:38.417 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/ErikZalm/Marlin/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:P802MA_8 EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000 20:50:38.437 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00 20:50:38.437 : echo:Active Extruder: 0 20:50:38.437 : Begin file list 20:50:38.437 : End file list 20:50:38.438 : Error:checksum mismatch, Last Line: 1 20:50:38.438 : Resend: 2 20:50:38.451 : Error:Line Number is not Last Line Number+1, Last Line: 1 20:50:38.451 : Resend: 2 20:50:38.473 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/ErikZalm/Marlin/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:P802MA_8 EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000 20:50:38.481 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00 20:50:38.484 : echo:Active Extruder: 0 20:50:38.487 : Begin file list 20:50:38.487 : End file list 20:50:38.493 : Error:Line Number is not Last Line Number+1, Last Line: 11 20:50:38.495 : Resend: 12 20:50:38.512 : echo:Active Extruder: 0 20:50:38.517 : echo:Active Extruder: 0 quindi già alla connessione ha qualcosa che non va. Per quanto riguarda la stampa non riesce a stampare sul piano,ho provato a modificare anche l'offset Z più volte, certe volte mi appare anche l'errore Z probe out bed. non so se ci sia qualche impostazione sballata, qualcuno mi sa aiutare? L'offset sembra essere sempre sbagliato o troppo alto o troppo basso, durante la stampa questo è il log 21:12:19.412 : Stampa layer 1 of 50 21:12:50.313 : No start signal detected - forcing start 21:12:52.670 : Printer reset detected - initializing 21:12:52.670 : start 21:12:52.670 : echo: External Reset 21:12:52.672 : Marlin1.0.0 21:12:52.678 : echo: Last Updated: Apr 7 2017 19:32:27 | Author: (none, default config) 21:12:52.681 : Compiled: Apr 7 2017 21:12:52.684 : echo: Free Memory: 11889 PlannerBufferBytes: 1232 21:12:52.687 : echo:Stored settings retrieved 21:12:53.001 : Error:volume.init failed 21:12:53.047 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/ErikZalm/Marlin/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:P802MA_8 EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000 21:12:53.057 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00 21:12:53.059 : echo:Active Extruder: 0 21:12:53.062 : Begin file list 21:12:53.062 : End file list 21:12:53.067 : Error:checksum mismatch, Last Line: 1 21:12:53.067 : Resend: 2 21:12:53.102 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/ErikZalm/Marlin/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:P802MA_8 EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000 21:12:53.110 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00 21:12:53.113 : echo:Active Extruder: 0 21:12:53.116 : Begin file list 21:12:53.116 : End file list 21:12:53.124 : Error:checksum mismatch, Last Line: 11 21:12:53.124 : Resend: 12 21:12:53.140 : echo:Active Extruder: 0 21:12:53.146 : echo:Active Extruder: 0 un altro problema che mi capita e che alcune volte il sensore non rileva il piatto e continua a bucare il piano, ma se metto un cacciavite sotto lo rileva e si ferma. SPERO CI SIA QUALCUN'ALTRO COME FONZY che sta cercando di darmi una mano 🙂 grazie a tutti Cita
marcottt Inviato 9 Dicembre 2019 Inviato 9 Dicembre 2019 Come@FoNzY è dura. Non ho la più pallida idea di come sia fatta la tua stampante... In attesa mi viene da dire che il primo tipo di errore è vero ma accertati che sia veramente tale (a volte gli informatici sono troppo pigri).Per il sensore se potessi aggiungere che sensore hai e che piatto hai sarebbe utile... Se è tutto stock e recente contattare produttori e/o fornitori non fa mai male... Inviato dal mio tablet utilizzando Tapatalk 1 Cita
xxREVENGExx Inviato 9 Dicembre 2019 Autore Inviato 9 Dicembre 2019 7 minuti fa, marcottt dice: Come@FoNzY è dura. Non ho la più pallida idea di come sia fatta la tua stampante... In attesa mi viene da dire che il primo tipo di errore è vero ma accertati che sia veramente tale (a volte gli informatici sono troppo pigri). Per il sensore se potessi aggiungere che sensore hai e che piatto hai sarebbe utile... Se è tutto stock e recente contattare produttori e/o fornitori non fa mai male... Inviato dal mio tablet utilizzando Tapatalk la stampante mi è stata regalata perchè non l'hanno mai saputa usare. E' stata comprata e mai usata non ha mai stampato. Le prime stampe le ho fatte io orrende ma le ho fatte.. XD comunque il piano è in metallo, il sensore è un tronxy xy-08n Cita
marcottt Inviato 9 Dicembre 2019 Inviato 9 Dicembre 2019 Sopra il piatto hai vetro? Se si quanto spesso? Inviato dal mio tablet utilizzando Tapatalk Cita
xxREVENGExx Inviato 9 Dicembre 2019 Autore Inviato 9 Dicembre 2019 2 minuti fa, marcottt dice: Sopra il piatto hai vetro? Se si quanto spesso? Inviato dal mio tablet utilizzando Tapatalk nono niente vetro, con fonzi tramite whats stiamo facendo un paio di prove. ora il sensore sembra andare. ma non si arriva ad un dunque per farla stampare. Cita
marcottt Inviato 9 Dicembre 2019 Inviato 9 Dicembre 2019 Potrebbe essere una completa stupidaggine ma sai a che tensione hai alimentato il sensore? Leggo che forse 3.3v che molte mainboard offrono non è abbastanza. (controlla dal tablet non si capisce così bene) Inviato dal mio tablet utilizzando Tapatalk Cita
xxREVENGExx Inviato 9 Dicembre 2019 Autore Inviato 9 Dicembre 2019 Adesso, marcottt dice: Potrebbe essere una completa stupidaggine ma sai a che tensione hai alimentato il sensore? Leggo che forse 3.3v che molte mainboard offrono non è abbastanza. (controlla dal tablet non si capisce così bene) Inviato dal mio tablet utilizzando Tapatalk CHE TABLET? comunque sul sensore c'è scritto DC 6 - 36 volt Cita
marcottt Inviato 9 Dicembre 2019 Inviato 9 Dicembre 2019 [emoji23] [emoji23] Il mio tablet.Esatto il sensore richiede minimo 6 volt. Hai idea di dove lo hai collegato che tensione gli dai? Inviato dal mio tablet utilizzando Tapatalk Cita
xxREVENGExx Inviato 9 Dicembre 2019 Autore Inviato 9 Dicembre 2019 3 minuti fa, marcottt dice: Il mio tablet. Esatto il sensore richiede minimo 6 volt. Hai idea di dove lo hai collegato che tensione gli dai? Inviato dal mio tablet utilizzando Tapatalk No purtroppo non ne ho idea😅 comunque ho provato 10 mila offset Z ma continua sempre a toccare sul piatto l estrusore e non stampa, può essere che è settato male questo sensore? Da cos altro può dipendere? Le sto provando tutte ma non vedo risultati, mi sto scoraggiando. Magari è una cavolata veramente, sta di fatto che cambiando offset non cambia niente, cambiando altezza primo layer a 1.0 riesce a stampare, ovviamente orrendamente. A 0.2/0.3 non esce niente. Cita
marcottt Inviato 10 Dicembre 2019 Inviato 10 Dicembre 2019 Che scheda madre hai e dove la hai collegata? Ma livellare a mano intanto non puoi? Inviato dal mio tablet utilizzando Tapatalk Cita
