Tronxy p802ma problemi STAMPA
Buonasera avevo aperto già una discussione relativi a problemi con questa stampante, prima stampava solamente male, ora non riesce proprio a stampare, è una TRONXY P802MA CON SENSORE, Tramite repetier host vedo alcuni errori nei LOG, ho appena reinstallato repetierhost ho fatto la connessione e mi dice cosi, ho evidenziato gli errori.
20:50:38.054 : start
20:50:38.054 : echo: External Reset
20:50:38.054 : Marlin1.0.0
20:50:38.054 : echo: Last Updated: Apr  7 2017 19:32:27 | Author: (none, default config)
20:50:38.054 : Compiled: Apr  7 2017
20:50:38.054 : echo: Free Memory: 11889  PlannerBufferBytes: 1232
20:50:38.056 : echo:Stored settings retrieved
20:50:38.371 : Error:volume.init failed
20:50:38.417 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/ErikZalm/Marlin/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:P802MA_8 EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
20:50:38.437 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00
20:50:38.437 : echo:Active Extruder: 0
20:50:38.437 : Begin file list
20:50:38.437 : End file list
20:50:38.438 : Error:checksum mismatch, Last Line: 1
20:50:38.438 : Resend: 2
20:50:38.451 : Error:Line Number is not Last Line Number+1, Last Line: 1
20:50:38.451 : Resend: 2
20:50:38.473 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/ErikZalm/Marlin/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:P802MA_8 EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
20:50:38.481 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00
20:50:38.484 : echo:Active Extruder: 0
20:50:38.487 : Begin file list
20:50:38.487 : End file list
20:50:38.493 : Error:Line Number is not Last Line Number+1, Last Line: 11
20:50:38.495 : Resend: 12
20:50:38.512 : echo:Active Extruder: 0
20:50:38.517 : echo:Active Extruder: 0
quindi già alla connessione ha qualcosa che non va.
Per quanto riguarda la stampa non riesce a stampare sul piano,ho provato a modificare anche l'offset Z più volte, certe volte mi appare anche l'errore Z probe out bed. non so se ci sia qualche impostazione sballata, qualcuno mi sa aiutare?
L'offset sembra essere sempre sbagliato o troppo alto o troppo basso, durante la stampa questo è il log
21:12:19.412 : Stampa layer 1 of 50
21:12:50.313 : No start signal detected - forcing start
21:12:52.670 : Printer reset detected - initializing
21:12:52.670 : start
21:12:52.670 : echo: External Reset
21:12:52.672 : Marlin1.0.0
21:12:52.678 : echo: Last Updated: Apr  7 2017 19:32:27 | Author: (none, default config)
21:12:52.681 : Compiled: Apr  7 2017
21:12:52.684 : echo: Free Memory: 11889  PlannerBufferBytes: 1232
21:12:52.687 : echo:Stored settings retrieved
21:12:53.001 : Error:volume.init failed
21:12:53.047 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/ErikZalm/Marlin/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:P802MA_8 EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
21:12:53.057 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00
21:12:53.059 : echo:Active Extruder: 0
21:12:53.062 : Begin file list
21:12:53.062 : End file list
21:12:53.067 : Error:checksum mismatch, Last Line: 1
21:12:53.067 : Resend: 2
21:12:53.102 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/ErikZalm/Marlin/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:P802MA_8 EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
21:12:53.110 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00
21:12:53.113 : echo:Active Extruder: 0
21:12:53.116 : Begin file list
21:12:53.116 : End file list
21:12:53.124 : Error:checksum mismatch, Last Line: 11
21:12:53.124 : Resend: 12
21:12:53.140 : echo:Active Extruder: 0
21:12:53.146 : echo:Active Extruder: 0
un altro problema che mi capita e che alcune volte il sensore non rileva il piatto e continua a bucare il piano, ma se metto un cacciavite sotto lo rileva e si ferma.
SPERO CI SIA QUALCUN'ALTRO COME FONZY che sta cercando di darmi una mano 🙂 grazie a tutti
  • Risposte 19
Come@FoNzY è dura. Non ho la più pallida idea di come sia fatta la tua stampante... In attesa mi viene da dire che il primo tipo di errore è vero ma accertati che sia veramente tale (a volte gli informatici sono troppo pigri).
Per il sensore se potessi aggiungere che sensore hai e che piatto hai sarebbe utile... Se è tutto stock e recente contattare produttori e/o fornitori non fa mai male...
  • Haha 1
7 minuti fa, marcottt dice:
la stampante mi è stata regalata perchè non l'hanno mai saputa usare. E' stata comprata e mai usata non ha mai stampato. Le prime stampe le ho fatte io orrende ma le ho fatte.. XD comunque il piano è in metallo, il sensore è un tronxy xy-08n
Adesso, marcottt dice:
Potrebbe essere una completa stupidaggine ma sai a che tensione hai alimentato il sensore? Leggo che forse 3.3v che molte mainboard offrono non è abbastanza. (controlla dal tablet non si capisce così bene)
CHE TABLET? comunque sul sensore c'è scritto DC 6 - 36 volt
3 minuti fa, marcottt dice:
emoji23.pngemoji23.png Il mio tablet.
Esatto il sensore richiede minimo 6 volt. Hai idea di dove lo hai collegato che tensione gli dai?
No purtroppo non ne ho idea😅 comunque ho provato 10 mila offset Z ma continua sempre a toccare sul piatto l estrusore e non stampa, può essere che è settato male questo sensore? Da cos altro può dipendere? Le sto provando tutte ma non vedo risultati, mi sto scoraggiando. Magari è una cavolata veramente, sta di fatto che cambiando offset non cambia niente, cambiando altezza primo layer a 1.0 riesce a stampare, ovviamente orrendamente. A 0.2/0.3 non esce niente.
