invernomuto Inviato 21 Febbraio 2020 Condividi Inviato 21 Febbraio 2020 Appena uscito, di seguito il changelog: Cita Marlin 2.0.4 released. Marlin 2.0.4 Release Notes New Features G34 test points can now be auto-assigned Z_AFTER_HOMING for a standard raise after G28 Individual edge insets for corner leveling Separate config for secure data (Excluded by .gitignore) Boards / Pins Added MKS BASE 1.6 board support MKS RUMBA split up into AUS3D and MKS variants Improved support for Adafruit Grand Central M4 (SAMD51) Added RAMPS 1.4.4 Use RTC for the temperature (1kHz) timer Added old and new PICA Shield support Configuration Direct link to example configs for the current version Configurable G26 retraction length Configuration versions bumped to 020004 Don't require Z sensorless when homing with probe Sanity-check recommending safe homing with probes Simplify safe homing point sanity check Hosts and UI Cosmetic tweaks for character LCD ExtUI API support for PID, probe offsets Optional support for G-code quoted strings Updated FYSETC S6 pins, LCD settings Fixed fan speed editing, decimal value rounding Updated French, Russian, Italian Fixed STOP reply going to wrong serial port Added semicolon (comment prefix) to M503 headings HAL / Platforms Fixed LPC build with watchdog off Removed extraneous serial initialization Fixed bad pin state transitions on SAMD51 Fixed ESP32 extraneous library include Put the ESP32 stepper I2S task and Marlin on the same core Issues Patched Fixed a bug in TMC2209 StallGuard handling Fixed a bug preventing extruder motors being turned off Fixed Arduino IDE compilation for DUE Fixed SKR 1.4 "extra" endstop pins Add Trigorilla endstop add-on option Fixed M112 behavior with emergency parser Fixed end of print behavior with print status LEDs Fixed Neopixel white when used with other LEDs Further fixups for 8 extruders Ensure that UBL uses Tool 0 for bed leveling Fixed G425 CALIBRATION_GCODE pin handling Fixed a probe conflict with multi-endstop features Fixed MKS Robin nano build options Fixed DGUS serial ports not defined Display "*" when Trinamic stst = 0 Optimized / Improved Start and stop the print job timer on bed heating (also) Use SDIO for onboard SD with STM32duino boards Improved (safer) handling of probe failure For Developers Added mftest -b and -u options for auto-build Improved git, jekyll, and test helper scripts Refactored Probe as singleton class Define more EXP and AUX pins in SKR pins defines Added RREPEAT nested repeat macros and apply Added .editorconfig defining basic formatting Add logging for Z adjust when leveling is toggled Cleanup of host actions code To optimize auto-build drop some ATmega 1280 targets Cita Link al commento Condividi su altri siti Altre opzioni di condivisione...
Killrob Inviato 21 Febbraio 2020 Condividi Inviato 21 Febbraio 2020 buono a sapersi Cita Link al commento Condividi su altri siti Altre opzioni di condivisione...
Whitedavil Inviato 22 Febbraio 2020 Condividi Inviato 22 Febbraio 2020 È vecchia... Ce n'è già una nuova😅😅😅 1 Cita Link al commento Condividi su altri siti Altre opzioni di condivisione...
invernomuto Inviato 22 Febbraio 2020 Autore Condividi Inviato 22 Febbraio 2020 È vecchia... Ce n'è già una nuova[emoji28][emoji28][emoji28]Non ce fanno proprio a fare delle *stabili* che durino più di una settimana:-)Inviato dal mio SM-G965F utilizzando Tapatalk Cita Link al commento Condividi su altri siti Altre opzioni di condivisione...
Whitedavil Inviato 22 Febbraio 2020 Condividi Inviato 22 Febbraio 2020 Almeno però te lo dicono... Se usi mk4duo, l'autore aggiorna il fw senza aggiornare la versione e te ne accorgi solo perche cambia la data della release(e cambia quasi quotidianamente) e una bugfix non c'è.... La cosa scomoda è che non c'è una via semplice per importare i dati del fw precedente, per cui ogni volta ci smeni 2 ore ad aggiornare il fw Cita Link al commento Condividi su altri siti Altre opzioni di condivisione...
Killrob Inviato 22 Febbraio 2020 Condividi Inviato 22 Febbraio 2020 1 ora fa, Whitedavil dice: Almeno però te lo dicono... Se usi mk4duo, l'autore aggiorna il fw senza aggiornare la versione e te ne accorgi solo perche cambia la data della release(e cambia quasi quotidianamente) e una bugfix non c'è.... La cosa scomoda è che non c'è una via semplice per importare i dati del fw precedente, per cui ogni volta ci smeni 2 ore ad aggiornare il fw una fregatura se hai fatto modifiche pesanti... Cita Link al commento Condividi su altri siti Altre opzioni di condivisione...
