Obiettivi di vmecu82
skr e3 mini v1.2 + mini12864 v1.0
vmecu82 ha risposto a vmecu82 nella discussione Problemi generici o di qualità di stampa
forse ci sono: https://www.smith3d.com/guide-to-connect-btt-mini-12864-to-skr-mini-e3-v3/ -
se uso FYSETC_MINI_12864_1_2 serve rgb. mentre per FYSETC_MINI_12864_2_1 serve neo.... https://github.com/bigtreetech/MINI-12864/blob/master/mini12864_v1.0/Hardware/Bigtreetech Mini12864 V1.0 User Manual.pdf Qui dice che va bene, FYSETC_MINI_12864_2_1 ma secondo me dice che non lo supporta la skr e3 mini 1.2. perche' devo modificare qualcosa nel cfg della board? /** * _____ * 5V | 1 2 | GND * (LCD_EN) PB7 | 3 4 | PB8 (LCD_RS) * (LCD_D4) PB9 | 5 6 PA10 (BTN_EN2) * RESET | 7 8 | PA9 (BTN_EN1) * (BTN_ENC) PB6 | 9 10| PB5 (BEEPER) * ----- * EXP1 */ #define EXPA1_03_PIN PB7 #define EXPA1_04_PIN PB8 #define EXPA1_05_PIN PB9 #define EXPA1_06_PIN PA10 #define EXPA1_07_PIN -1 #define EXPA1_08_PIN PA9 #define EXPA1_09_PIN PB6 #define EXPA1_10_PIN PB5 #if HAS_SPI_LCD #if ENABLED(CR10_STOCKDISPLAY) #define BEEPER_PIN EXPA1_10_PIN #define BTN_EN1 EXPA1_08_PIN #define BTN_EN2 EXPA1_06_PIN #define BTN_ENC EXPA1_09_PIN #define LCD_PINS_RS EXPA1_04_PIN #define LCD_PINS_ENABLE EXPA1_03_PIN #define LCD_PINS_D4 EXPA1_05_PIN #elif ENABLED(ZONESTAR_LCD) // ANET A8 LCD Controller - Must convert to 3.3V - CONNECTING TO 5V WILL DAMAGE THE BOARD! #error "CAUTION! ZONESTAR_LCD requires wiring modifications. See 'pins_BTT_SKR_MINI_E3.h' for details. Comment out this line to continue." #define LCD_PINS_RS EXPA1_05_PIN #define LCD_PINS_ENABLE EXPA1_09_PIN #define LCD_PINS_D4 EXPA1_04_PIN #define LCD_PINS_D5 EXPA1_06_PIN #define LCD_PINS_D6 EXPA1_08_PIN #define LCD_PINS_D7 EXPA1_10_PIN #define ADC_KEYPAD_PIN PA1 // Repurpose servo pin for ADC - CONNECTING TO 5V WILL DAMAGE THE BOARD! #elif EITHER(MKS_MINI_12864, ENDER2_STOCKDISPLAY) /** Creality Ender-2 display pinout * _____ * 5V | 1 2 | GND * (MOSI) PB7 | 3 4 | PB8 (LCD_RS) * (LCD_A0) PB9 | 5 6 PA10 (BTN_EN2) * RESET | 7 8 | PA9 (BTN_EN1) * (BTN_ENC) PB6 | 9 10| PB5 (SCK) * ----- * EXP1 */ #define BTN_EN1 EXPA1_08_PIN #define BTN_EN2 EXPA1_06_PIN #define BTN_ENC EXPA1_09_PIN #define DOGLCD_CS EXPA1_04_PIN #define DOGLCD_A0 EXPA1_05_PIN #define DOGLCD_SCK EXPA1_10_PIN #define DOGLCD_MOSI EXPA1_03_PIN #define FORCE_SOFT_SPI #define LCD_BACKLIGHT_PIN -1 #else #error "Only ZONESTAR_LCD, MKS_MINI_12864, ENDER2_STOCKDISPLAY, and CR10_STOCKDISPLAY are currently supported on the BIGTREE_SKR_MINI_E3." #endif #endif // HAS_SPI_LCD -
ok, ho messo //#define CR10_STOCKDISPLAY l'unico abilitato. ora ottengo questo errore: #error "Only ZONESTAR_LCD, MKS_MINI_12864, ENDER2_STOCKDISPLAY, and CR10_STOCKDISPLAY are currently supported on the BIGTREE_SKR_MINI_E3." ^~~~~ -
Ciao, @dnasini si provato ma non funziona. in lcd/dogm/ultralcd_DOGM.cpp (u8g.setContrast(255);) in configuration.h tolto (//) #define FYSETC_MINI_12864_1_2 continua a darmi questi errori: Unpacking [####################################] 100% Library Manager: SoftwareSerialM@1.0.0 has been installed! In file included from Marlin/src/HAL/STM32F1/../../inc/MarlinConfig.h:40:0, from Marlin/src/HAL/STM32F1/HAL.cpp:30: Marlin/src/HAL/STM32F1/../../inc/SanityCheck.h:2076:4: error: #error "Please select no more than one LCD controller option." #error "Please select no more than one LCD controller option." ^~~~~ Marlin/src/HAL/STM32F1/../../inc/SanityCheck.h:2091:4: error: #error "RGB_LED is required for FYSETC_MINI_12864 1.2 and 2.0." #error "RGB_LED is required for FYSETC_MINI_12864 1.2 and 2.0." ^~~~~ In file included from Marlin/src/HAL/STM32F1/../../inc/MarlinConfig.h:40:0, from Marlin/src/HAL/STM32F1/HAL_SPI.cpp:35: Marlin/src/HAL/STM32F1/../../inc/SanityCheck.h:2076:4: error: #error "Please select no more than one LCD controller option." #error "Please select no more than one LCD controller option." ^~~~~ Marlin/src/HAL/STM32F1/../../inc/SanityCheck.h:2091:4: error: #error "RGB_LED is required for FYSETC_MINI_12864 1.2 and 2.0." #error "RGB_LED is required for FYSETC_MINI_12864 1.2 and 2.0." ^~~~~ *** [.pio/build/STM32F103RC_btt/src/src/HAL/STM32F1/HAL.cpp.o] Error 1 *** [.pio/build/STM32F103RC_btt/src/src/HAL/STM32F1/HAL_SPI.cpp.o] Error 1 Quindi abilito rgb? grazie. Abilitando: #define RGB_LED mi da questo errore: Marlin/src/HAL/STM32F1/../../inc/SanityCheck.h:1972:6: error: #error "RGB_LED requires RGB_LED_R_PIN, RGB_LED_G_PIN, and RGB_LED_B_PIN." #error "RGB_LED requires RGB_LED_R_PIN, RGB_LED_G_PIN, and RGB_LED_B_PIN." ^~~~~ Marlin/src/HAL/STM32F1/../../inc/SanityCheck.h:2076:4: error: #error "Please select no more than one LCD controller option." #error "Please select no more than one LCD controller option." ^~~~~ In file included from Marlin/src/HAL/STM32F1/../../inc/MarlinConfig.h:40:0, from Marlin/src/HAL/STM32F1/HAL_SPI.cpp:35: Marlin/src/HAL/STM32F1/../../inc/SanityCheck.h:1972:6: error: #error "RGB_LED requires RGB_LED_R_PIN, RGB_LED_G_PIN, and RGB_LED_B_PIN." #error "RGB_LED requires RGB_LED_R_PIN, RGB_LED_G_PIN, and RGB_LED_B_PIN." ^~~~~ Marlin/src/HAL/STM32F1/../../inc/SanityCheck.h:2076:4: error: #error "Please select no more than one LCD controller option." #error "Please select no more than one LCD controller option." ^~~~~ *** [.pio/build/STM32F103RC_btt/src/src/HAL/STM32F1/HAL.cpp.o] Error 1 *** [.pio/build/STM32F103RC_btt/src/src/HAL/STM32F1/HAL_SPI.cpp.o] Error 1 ok, ho abilitato questi: #define RGB_LED //#define RGBW_LED #if EITHER(RGB_LED, RGBW_LED) #define RGB_LED_R_PIN 34 #define RGB_LED_G_PIN 43 #define RGB_LED_B_PIN 35 //#define RGB_LED_W_PIN -1 #endif ma rimane solo l'errore :#error "Please select no more than one LCD controller option." -
nel 2.0.7.2 le ho trovate, ma non si vede nulla sul display. leggendo il git hub : https://github.com/VoronDesign/Voron-Hardware/blob/master/SKR-Mini_Screen_Adaptor/SRK Mini E3 V1.2-2.0/ScreenBreakout.cfg qui parla di cambiare i pin. meglio che passo a klipper? o posso anche per marlin? grazie. P.S. ho guardato sul web ma non ho trovato quello che cerco di fare. grazie ancora. -
Ciao e grazie, allora lo schermo e un rgb per i led che cambiano colore della retroilluminazione. queste stringhe da te elencate non le trovo nel configuration.h grazie. -
vmecu82 ha pubblicato una discussione in Problemi generici o di qualità di stampa
Ciao a tutti, come da titolo sto cercando di usare questo lcd rgb sulla skr e3 mini v1.2. Ho già creato il cavo doppio come da schema, il mio problema e che nel github menzionano cfg per firmware klipper. io uso il marlin 2.0.5.3, ho guardato sul qui forum ma ho trovato soluzione. qualcuno sa come e dove vanno editati nel marlin? https://github.com/VoronDesign/Voron-Hardware/blob/master/SKR-Mini_Screen_Adaptor/SRK Mini E3 V1.2-2.0/ScreenBreakout.cfg grazie e buone feste... Dimenticavo il display e questo: https://github.com/bigtreetech/BTT-Expansion-module/tree/master/BTT Mini12864?spm=a2g0o.detail.1000023.17.303338aaBrV1Mz -
Problema fw longer lk4
Ciao a tutti, ho risolto il problema, in pratica erano da sistemare l'asse x (come detto prima) in più gli end stop da invertire. // Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup). #define X_MIN_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop. #define Y_MIN_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop. #define Z_MIN_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop. #define X_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop. #define Y_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop. #define Z_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop. #define Z_MIN_PROBE_ENDSTOP_INVERTING false // Set to true to invert the logic of the probe. i primi 3 andavano messi true nel mio caso. ora stampa da dio come prima. grazie comunque. -
Ecco il mio setup: 3 motori: longer 42BYGH40H-2-19D KH 2019 8 05 Psu 360w 24v piatto misurato 235 x 235 main: skr mini e3 v1.2 -
Grazie, infatti quando l'acquistai era gia compilata dal tizio, solo che lk4 longer devo trovare un conf.h e vedere cosa cambia. l'unica cosa che so: l'asse invertita. https://github.com/AstroMasztalerz/Longer-LK4-Marlin-E3D-V6-Volcano/blob/master/config/default/Configuration.h Questo e quello che ho trovato. se qualcuno mi aiuta e posso fornire tutte le info della stampante. -
Ciao il firmware della skr esiste sul github, io non sono esperto, con lo slicer lo converto in gcode e bona. il firmware non volevo caricarlo, anche perche' non ne capisco nulla. ecco il link: https://github.com/bigtreetech/BIGTREETECH-SKR-mini-E3/tree/master/firmware/V1.2 Ho solo invertito l'asse X, nome, e lingua in italiano. il mio problema e che se stampo lavora non sul piatto ma in aria, quando calibravo il piatto con i 9 punti andava da dio. Vorrei risolvere questo casino. Allora l'asse X e ok: prima #define INVERT_X_DIR true #define INVERT_Y_DIR true #define INVERT_Z_DIR false e dopo #define INVERT_X_DIR false #define INVERT_Y_DIR true #define INVERT_Z_DIR false nel firmware lo so che c'e' il punto zero, ma la stampante non va correttamente, i motori sono marchiati longer: longer 42BYGH40H-2-19D KH 2019 8 05 -
Ciao a tutti, ho un problema con la mia longer lk4, acquistata usata e funzionante. Per errore ho inserito una sd nella board (dove carico il file stl) con un firmware, di conseguenza e partito l'update e quindi perso tutti gli home eccetera, questa stampante monta una scheda skr mini e3 v1.2 (migliore di quella nativa presumo) Non avendo copia del firmware compilato che era installato (marlin2.0.5.3) ho provato a scaricare dal github della bigtreetech e compilarlo. il 2.0.5.3 lo compilo ma il driver non funziona su pc e non riesco ad impostare gli homeépenso siano i punti zero) se compilo il 2.0.7.2 i driver su pc funziona e quindi uso repiter_host. però anche qui secondo me la stampante non ha il suo punto zero. ho provato mille modi ma senza successo. premetto che lunica cosa che ho capito e che l'asse X devo invertirla e qui ok. spero che qualcuno possa aiutarmi. Qui il platform: https://pastebin.com/E76AaDmr qui il configuration: https://pastebin.com/X6zUQMMy Thanks all guys..... -
Ciao a tutti, mi chiamo Valentino, da poco sono entrato nel mondo delle stampanti 3d. spero di imoarare molto qui grazie a tutti voi... Modello stampante: longer lk4 con scheda skr mini e3 v1.2
- 1
