non ho compilato niente ho seguito le istruzioni che dice il produttore, mettere il file bin nel pennino ed all'avvio lei installa il firmware nel giro di 10 secondi e fa una sorta di diagnostica
Firmware of motherboard Caution The package contains the firmware for testing (Ender3), which can be used directly or changed according to your needs. The text form and file name of firmware in the SD card cannot be changed from “firmware.bin”. The wiring must be done before powering on. The LCD screen only supports the LCD12864 screen with CR10_STOCKDISPLAY interface. How to get the firmware Contact our customer service or technical support; Login to our website to download: https://github.com/bigtreetech Please refer to the BTT SKR MINI E3 V3.0-PIN.pdf for motherboard firmware DIY. Motherboard firmware update Copy firmware.bin file to the root directory of SD card Insert the SD card into the slot, re-power on or reset, the update will complete after 10S, And you should see the status LED blinking red during the update..
