Dispelling the Carbon Fiber Myth: Chopped vs Continuous Fibers
Alessandro Tassinari ha pubblicato un evento del calendario in Community Calendar
fino leWednesday March 24, 2021 10 AM EST / 3 PM GMT Carbon fiber is perhaps the second most sought-after additive manufacturing material, after metal. Thanks to recent developments in the additive manufacturing space, carbon fiber materials are finally catching on across the industry. Whether it’s blended with PETG, PEEK, or nylon, printer and filament manufacturers alike boast of carbon fiber’s ability to enhance the surface finish, strength, and thermal properties of printed parts. And for the most part, that’s true. However, not all carbon fiber 3D printers are created equal — while microscopic chopped fibers can enhance the strength of printed parts to rival those of molded thermoplastics, only the Continuous Fiber Reinforcement process invented by Markforged can boost mechanical properties by an order of magnitude for true replacement of metal components. We invite you to join our webinar as we take a deep dive into the role of carbon fiber in 3D printing. In this webinar, we will cover: The physics behind 3D printed carbon fiber Comparison of chopped and continuous fiber parts and why not all 3D printed carbon fiber parts are the same Practical considerations for using carbon fiber in engineering applications Registrati a questo link. -
Maaaaa... Un database per i materiali, no?
Alessandro Tassinari ha risposto a Otto_969 nella discussione Materiali di stampa
READY -> https://www.stampa3d-forum.it/database-materiali/ Vi spiego velocemente: a questo link trovate il Database. Lo trovate anche attraverso una nuova voce nel menu della community, sotto "Risorse utili". Il Database utilizza due sottocategorie filamenti; resine (non ancora del tutto operativa); per ogni "Scheda materiale" sono definibili i parametri di base per stampare col materiale specifico; ogni Scheda materiale può essere aggiornata in modalità Wiki, le revisioni vengono salvate dal sistema ed è sempre possibile tornare indietro al momento la possibilità di modificare i dati delle Schede è aperta a tutti. Vedremo se la cosa funziona o meno; ogni volta che viene pubblicata una nuova Scheda materiale, viene automaticamente aperta una discussione nell'apposito forum che trovate a questo link in queste discussioni sarà possibile confrontarsi sull'uso del materiale in oggetto. Proviamo e vediamo se la cosa funziona. Se ci sono errori, problemi, mancanze, segnalate pure. -
Secondo voi faremo qualcosa di simile anche per le resine? Se sì, avete parametri comunemente usati da elencare? -
Nuovi arrivati - Anycubic Chiron
Alessandro Tassinari ha risposto a CiccioTi nella discussione Presentazioni
Siete benvenuti! -
Avendola usata, non credo sia molto comoda da usare in ambito 3D o, più in generale, nel disegno cad.
L'ho usata per tanto tempo, ma per fare lavori di grafica su Photoshop e Illustrator. Per la modellazione 3D te la sconsiglio, ma c'è chi la usa ed è felice. La mia era una Wacom Bamboo, sarà stata un A5 di dimensione, con 4 tasti se ricordo bene. Ce l'ho ancora da qualche parte! Io mi sono convertito ai mouse 3DConnexion, in particolare allo SpaceMouse. Dopo un impatto iniziare un po' brusco, ora non ne posso fare a meno!
@Tanbruk capita, spesso quando si va sul tecnico partono gli inglesismi. Abbi pazienza. @eaman si possi abilitare un database in formato wiki. Lo metterei in risalto nell'apposita sezione. Mi sembra una buona soluzione da provare. -
presentazione nuovo del forum
Alessandro Tassinari ha risposto a luigi89 nella discussione Presentazioni
Benvenuto! Certo che possiamo aiutarti, non qui ma nell'apposita sezione del forum. -
Questo sarebbe fattibile. La piattaforma mi permette di abilitare contenuti Wiki-style, editabili da tutti gli utenti. Si potrebbe sperimentare con questo utilizzo in ambito materiali. Proviamo a definire cosa ci serve lato operativo? La scheda che propone @Otto_969 mi sembra valida: mi immagino che la pagina Wiki metta a disposizione soltanto quei campi o poco altro per evitare dispersione di informazioni. Visione più ampia -> Prossimamente avevo intenzione di potenziare l'area Profili di stampa, inserendo una nuova applicazione che permette di caricare e scaricare file. Ogni profilo di stampa avrebbe una sua breve descrizione e in risalto le informazioni di base (stampante 3D utilizzata, layer height, ecc). Verrebbe fuori un'area molto similare a questa. Mi sembra di capire che questa sorta di Wiki Materiali che stiamo ideando non vada a soprapporsi, ma prima di mettermi all'opera vorrei assicurarmi che non vengano fuori doppioni. Chiedo consiglio anche al fidato @Killrob e a @eaman. -
Benvenuto! Non so quanto consigliarti i manualetti, quelli oiù economici non li ritengo validi per imparare cose nuove, li trovo molto basici. L'unico che mi sento di consigliare è eD Printing Handbook, ma non si focalizza solo sulla FDM. Per il resto, puoi chiedere qui nella community tutto quello che ti serve 😉
La stampa 3D per l'industria elettronica: materiali e applicazioni
La produzione elettronica è caratterizzata dall'esigenza di realizzare attrezzature con materiali ESD. Che si tratti di fixture di collaudo o vassoi per la movimentazione dei PCB, è oggi possibile utilizzare la stampa 3D per costruire queste attrezzature in completa autonomia, ad un costo di molto inferiore rispetto al passato. Inoltre, per produzioni di piccole serie è anche possibile realizzare contenitori di design stampati in 3D utilizzando materiali certificati V0 secondo UL-94, quindi adatti a contenere apparecchi in tensione.In questo webinar gratuito avrai la possibilità di scoprire le peculiarità della tecnologia di stampa 3D Markforged, abbinata all'impiego di materiali tecnologici innovativi come l'ONYX ESD (statico dissipativo) e l'ONYX FR (autoestinguente UL-94 V0).Al termine del webinar ci sarà la possibilità di richiedere un campione e porre domande al relatore. ISCRIVITI AL WEBINAR L'evento è organizzato da 3DCompany, tutti i diritti riservati. -
Buongiorno community! Come sicuramente i più attenti avranno notato, da qualche giorno è comparsa una nuova voce nel menu del sito, intitolata "Prodotti consigliati". Nelle prossime righe vi dirò velocemente di cosa si tratta. Una guida all'acquisto per Stampa 3D forum Forse qualcuno ricorderà: nel 2018, sollecitato da alcuni utenti della community, pubblicai un articolo dove consigliavo una serie di strumenti utili a stampare in 3D. Non solo stampanti e materiali, ma anche strumenti da utilizzare in laboratorio. Alcuni mi presero in giro, perché avevo inserito nella lista anche un grande tavolo da lavoro... poi però dovettero ricredersi vista l'effettiva utilità di quel prodotto! Ebbene, la pagina Prodotti consigliati è un grosso aggiornamento di quel mio vecchio articolo. Al suo interno trovate una lista in costante aggiornamento sui prodotti che io stesso uso, che ho usato, o che miei contatti mi hanno consigliato. Come vedrete, tutti i prodotti rimandano ad Amazon. I motivi sono due: da anni ormai acquisto tramite il servizio Amazon Prime. La spedizione veloce in 1 giorno e l'affidabilità sono eccellenti; ormai su Amazon si trovano tanti prodotti connessi alla stampa 3D, non ha più molto senso aspettare per settimane delle spedizioni che arrivano dall'estero. Insomma, dovete vedere questa pagina come se un amico vi consigliasse qualcosa di nuovo da provare! Spero vivamente sia di vostro gradimento. A presto!
Benvenuto!
Installazione Carbon 3D
Alessandro Tassinari ha risposto a Alessandro Tassinari nella discussione Stampa 3D industriale
Se hai il business giusto, 0! -
Stamattina in fase di installazione un sistema Carbon 3D, in sede Juno Design. Avanti con la produzione! 💥
Ciao, benvenuto!
I progettisti sono sempre i benvenuti 😉
Consigli per iniziare con la post-produzione delle stampe 3d
Alessandro Tassinari ha risposto a Toretto. nella discussione La mia prima stampante 3D
Buona lettura! 🙂 -
Immagino una modalità di questo tipo. Facciamolo, credo sia utile alla community! Mi prendo qualche giorno per vedere come fare lato Admin 😉 -
Eviterei procedure di upload-download di file o attività di controllo da parte dello staff. Soprattutto perché è scomodo scaricare il file per cercare i dati. Possiamo adottare un sistema del tutto open e gestito in rete, come se fosse una dashboard aperta dove si accede e si possono inserire/modificare dati. Oppure cerco un modo alternativo all'interno della piattaforma che ospita la nostra community. In alternativa, e per semplificare: se facessimo delle discussioni del forum dedicate e chiuse? Esempio: ho provato il nuovo FiloAlfa. Uso un titolo standard che abbiamo definito e la struttura del contenuto è più o meno standardizzata con introduzione, descrizione e opinioni. Si inseriscono dati di parametri e info utili. La discussione viene chiusa, quindi risulta come se ci fosse un database di info. -
Che svista! Scusatemi, ma quei contenuti sono ancora "nascosti" perchè incompleti. Praticamente li vedo solo io! Peró si tratta di una guida ai materiali, impostata come il resto delle guide (Introduzione dovreste essere in grado di vederla tutti: https://www.stampa3d-forum.it/guida-stampa-3d/guida/). Sono delle "schede" navigabili dedicate a PLA, ABS, ecc. -
Una cosa simile a quella che avete citato é quella che ho impostato qui: https://www.stampa3d-forum.it/guida-stampa-3d/materiali-stampa-3d/ Il progetto "guida" é in corso d'opera, anche in relazione ai materiali. Proprio come propone @Otto_969, ogni scheda ha una descrizione materiale. Qui peró non si entra in merito a specifici produttori. Se riteniamo sia d'interesse entrare cosí in dettaglio, cerchiamo un modo di farlo. Altra cosa a cui pensavo, era di collezionare profili e metterli a disposizione della community, tipo una "sezione download". Magari é d'interesse. -
Mi sembra una buona idea, ma sarebbe da strutturare bene per evitare confusione e rendere le discussioni facilmente recuperabili. Pensiamoci! -
modellazione a rete
Alessandro Tassinari ha risposto a Maurizio Cris nella discussione Problemi di modellazione 3D, gestione mesh, esportazione in stl
@Maurizio Cris dovessi farlo io, andrei su Grasshopper vista la larga libertà nel generare forme e geometrie, ma mi rendo conto non sia uno strumento accessibile o facilmente utilizzabile. Hai poi fatto prove? Sarei curioso di vedere il risultato! -
Forse stai estrudendo poco materiale? Hai modificato i parametri di stampa recentemente, tipo il flow o similari?
