photoholic
Obiettivi di photoholic
  1. yes I appologize again... I didn't know things were already this messy... I just don't get it... what is the Strategy of Zortrax? Why using another code format if you're not able to do things better, faster and more reliable this way? They're already loosing customers to Raise3D and others and the M300 is quite a little overprized.... but now back to the interesting stuff... the 3d printing ;) as I told already the g2z seems to work great with the M300... but I'm having troubles getting enough separation between raft and print or support and print. It's melting together completely. I will play around with the separation parameter (raft and support section in simplify3d) later but probably you already know what to change (I tried with Polymaker Polymax (215/65))? grazie mille
  2. absolutely genious... it works like a charm!!!! it worked fine for me... guess the bed moves always down set by firmware...
  3. Wow I'm absolutely excited... been owning my M300 for about 10 days now (had an i3 MK2 and a Raise3D N2 before) getting already tired about the limitations of Z-Suite. Will try this and is there a paypal account to donate if it works? Does the "Separation Distance" parameter in the raft options translate to z-code? Thanks a lot for the fantastic work
