sylus
Obiettivi di sylus
  1. Dear 0xdeadbeef new firmware came this month, have you take a look if it change something in Ztool?
  2. @0xdeadbeef yes it is
  3. just M226 after heating code is neccesary because it recall firmware pause witch include filament change process
  4. Many thanks for quick update ,i will experiment you work within hours
  5. Ok let's wait Zortrax update thanks again for this work
  6. Nice work, I try to create an fake Zcode for load and unload PLA (less temperature than firmware setting) but i fail when i remove the object and less start and end gcode could you assist me regarding your knowledge with Zcode protocole it could be: G91 M82 M106 S0 M140 S20 M190 S20 M104 S235 T0 M109 S235 T0 G92 E0 G1 E-50 F300 ;extract filament distance and speed to define M25 ;pause or Zcode pause with prompt?? G1 E50 F300 ; purge nozzle quickly extract filament distance and speed to define G1 E10 F60 ; purge nozzle slowly G92 E0 ; zero the extruded length again M104 S0 ; turn off extruder M106 S0 ; turn off fan Thanks for your assistance
