Nagisa
Obiettivi di Nagisa
ZDump is dead, long live ZTool
Nagisa ha risposto a 0xdeadbeef nella discussione Problemi generici o di qualità di stampa
Preview issue? I set 50% fan for 6th layer in S3D, it's correct in g-code. But in ZTool preview, the fan start from "Layer 4/15" (5th layer, 0 is the 1st layer, total 16 layers) -
Actually my computer have some problem, can't run 1.6.x, so I didn't test 1.6.x. Z-Suite is very weak and too many limitation, I do more S3D and Ztool test recently, it's very powerful, especially editing g-code can make everything, I really enjoy it, so I think good convert function is more useful and important. -
All versions have been fixed. Thanks for your great work, beef. -
OK. Second have been fixed. 0.0.9.6.zcode 1.3.0.zcode 1.5.0.1.zcode 1.7.2.1.zcode 1.8.0.zcode -
Sorry for my bad English expression. I didn't set to 0%, I set to 100%, same fpf, but different version zcode result differently. fpf only 3 statement: V1.5.0.2&previous version zcode after load: V.1.7.2.1 & V1.8 zcode after load, only last 3 layers, and drop to 0%. V1.9&V1.10 zcode after load, perfect. -
After test, I find this problem happen to Z-Suite v1.5 and previous version. V.1.7.2.1 & V1.8 have a minor bug, the fan only last 3 layers, and drop to 0%. This is V1.8.0 original fan, I'm not sure it's Z-Suite or Ztool problem. V1.9&V1.10, haven't find any problem. -
I have problem with Load Fan Profile, always set 0% from start to end, even I don't edit the original fpf. I'm using 1.0.3b. I save again after load, no <layer>,<fan percentage> statement. -
OMG! Genius! -
The fan affect extrusion a lot in my case, sometimes fan changing will make obvious under or over extrusion, I print a lot, so I tested every version of Z-suite for one file, select the best zcode and then print again and again, I believe the old version zcode can be better if I can adjust the fan. But never mind, I decide to use S3D and Ztool, it's the ultimate solution. Thank you! -
Sometimes Z-Suite set fan inappropriately, so I think <layer>,percentage or <z-height>,percentage fan setting is enough and great for now. I download Zortrax m200_3_0.fff and find Z Axis Movement Speed is 8000 mm/min, is it M200 feature or I need to change it? -
Awesome software! Hope to add fan setting, that will be great.
