Nino
Tutti i contenuti di Nino
  1. Hej together & 0xdeadbeef thanks a lot for the amazing converting tool:) I updated and tweaked your provided Cura (and Slic3r) profiles for high quality prints up to 40/50 microns. Only tested with ABS (Z-ABS and others) on M200 1. Now the Cura profile prints ABS pretty good up to 40microns resolution / also changed build plate adhesion settings to Z-Suite standard 2. The Slic3r (PrusaEdition) also works with the variable layer height tool from 0,5 to 0,05mm / also changed build plate adhesion settings to Z-Suite standard (as far as possible) // Cura_Config_M200_40microns.curaprofile Slic3r_config_M200_flexheight_50microns.ini
