kohyarp
Obiettivi di kohyarp
  1. Hi 0xDeadbeef: Thanks for the update and your response. This code really is a great help to my research. I appreciate your efforts. Where we can download the new update? Does it compatible with the updated firmware of the Zortrax M200. I did not update to the latest firmware, I thought it might be incompatible with the code. Thanks. K
  2. Hi Beef and everyone: Thank you so much for such a useful app, you ere awesome Beef. I had difficulty to use it, I used slic3r Prusa to do the slicing in a sample object and then export and use the code to convert it to Zcode, I also used the uploaded configuration for slic3r. but when I print it with my newly acquired M200/V4 (1.1.1) the printer jammed, and it could not even start printing and I pulled the plug out to shout down the printer immediately. I tried it twice with little bit tweak, the same thing happened. the slic3r is version 1.38.2-prusa3d. I also get an error when importing the following configuration into the slic3r. It looks everyone here is happy with using this code and I assume it should be something wrong with my file or configuration. I load the original zcode from z-suit with converted code using g2z attached to this post for anyone that could give me a hint about the problem. the attached files are: wedge-zsuit.zcode: original zcode generated by zsuit version 2.2 slic3r configuration file, download from this post in top wedge_slic3r.gcode: original gcode generated by slic3r prusa wedge_slic3r_Z-ABS: the code generated by g2z Thanks! Slic3r_config_bundle_m200.ini wedge-zsuit.zcode wedge_slic3r.gcode wedge_slic3r_Z-ABS.zcode
