SIGMARILION
Tutti i contenuti di SIGMARILION
  1. SIGMARILION
    Mods per Sharebot NG
    Hi Leon , send me a private message for send you my rom thanks for help
  2. SIGMARILION
    hi LEO I can connect without any problem to the printer via usb 1) the latest version for win 10 64 bits is installed and cura lattest version and slic3r with sharebot ng 2 extruder perfil 2) that's my problem I know that with the .ino file you can do everything but I don't know how to send it to the rumba without breaking everything 😞 3) 18 + 23 years old? can i take one 4) tomorrow he will send me by mail what I use for the new marlin that he got, if he sends me his email privately I will send him a copy thanks for everything we will read next week
  3. SIGMARILION
    I have a sharebot ng as it left the factory, I bought it from a person who bought it and I never use it, max 3 hours of use, it has two extruders Due to personal, labor and economic problems, she cannot use it and learn from it, but in one of the moves and unfortunately from this pandemic I have been able to pay more attention to her, but what is my problem, after the move to my new apartment, the printer doesn't work I decide to take her to a printer site that tells me they can repair my problems: - Poorly calibrated bed - Don't heat the nozzle and I can't print (I think it's a bulb or thermistor) - Request to put the same marlin to my board but with the possibility of Spanish that is in the laguage.h file and I will not compile all the files from github to arduino to configure the marlin correctly ( I don't know how to change the language file and then compile it with arduino and put it in the rumba) - Remove the ghostering that I get when printing test cube with letters x y z and they do the following: - regulation of bed and change of springs because they were not very reliable - change of marlin on my printer (in a first attempt the usb breaks and I have to buy a new rumba) I go to 2.5 because they tell me that it is better because it has improvements, you can put bltouch, autolevel bed adjustment, layer fan to a better bowden, and a thousand more nonsense that I don't know if they were necessary. - adjustment of belts and extruders - they recommend me to print pipes for layer fans of thingiverse (the plane because the other one hits the lcd) It tells me that it is fine, only that it has two problems: - sometimes when printing it does not auto home and you have to restart the printing and the printer doing reset eprom - could not remove the ghostering because the machine is very powerful and the solution is to print much slower I take it home and my surprise is the following: I can't print the layer fan pipes because they don't glue the different layers ( tried to generate gcode with cura at 70mm and 35mm speed with supports and same procedure with slic3r with the official sharebot profile ) I try to print the xyz cube and it is impossible I try to print the sharebot_filament_glider with supports ( tried to generate gcode with cura at 70mm and 35mm speed with supports and same procedure with slic3r with the official sharebot profile ) it does not print well even makes layers in the air I try to print a marvin to try to complete it and see ghostering and I get an amorphous doll with many flaws and not well finished from layer to layer I have read in this forum that YOU have it in the same marling 2.5 as I have seen photos on the screen and I wonder if YOU can help me before I lose everything and sell it for a miserable money so that I can remove from the hands as soon as possible. P.S. sharebot's technical and support service asked a thousand times and with a thousand emails they have never answered me I thank you in advance for all the help you can give me because I am desperate I just want to print things and enjoy and be happy forget to tell you LEO I'm not in a hurry because nothing is going, enjoy your vacation
  4. SIGMARILION
    Metto in spagnolo nel caso in cui tu possa tradurre meglio
  5. SIGMARILION
    Buongiorno Sono contento di aver trovato questo forum, ti dico il mio problema: Ho un sharebot di quando ha lasciato la fabbrica, l'ho comprato da una persona che lo ha acquistato e non lo uso mai, max 3 ore di utilizzo, ha due estrusori A causa di problemi personali, lavorativi ed economici, non può usarlo molto e imparare da esso, ma in una delle mosse e sfortunatamente da questa pandemia sono stato in grado di prestarle più attenzione, ma qual è il mio problema, dopo il trasferimento nel mio nuovo appartamento, il la stampante non funziona Decido di portarla su un sito di stampa che mi dice che possono riparare i miei problemi: - Letto scarsamente calibrato - Non riscaldare l'ugello e non riesco a stampare (penso che sia una lampadina o un termistore) - Richiesta di mettere lo stesso marlin sulla mia bacheca ma con la possibilità dello spagnolo che si trova nel file laguage.h e non compilerò tutti i file da Github ad Arduino per configurare correttamente il Marlin - Rimuovi il ghostering che ottengo quando stampo il cubo di prova con le lettere xe z e fanno quanto segue: - regolazione del letto e cambio delle molle perché non molto affidabili - cambio di marlin sul mio piatto (in un primo tentativo l'USB si rompe e devo comprare un nuovo rumba) vado a 2.5 perché mi dicono che è meglio perché ha miglioramenti, puoi mettere bltouc, regolazione automatica del letto di livello, ventola di livello a un bowden migliore e mille altre sciocchezze che non so se fossero necessarie. - regolazione di cinghie ed estrusori - mi consigliano di stampare pipe per gli appassionati di layer di thingiverse (l'aereo perché l'altro colpisce l'LCD) Mi dice che va bene, solo che ha due inconvenienti: - a volte durante la stampa non si torna automaticamente a casa e è necessario riavviare la stampa e la stampante ripristina eprom - Impossibile rimuovere il ghostering perché la macchina è molto potente e la soluzione è stampare molto più lentamente Lo porto a casa e la mia sorpresa è la seguente: Non riesco a stampare i tubi della ventola dello strato perché non incollano i diversi strati (ho cercato di generare gcode con cura a 70mm e 35mm di velocità con supporti e stessa procedura con slic3r con il profilo sharebot ufficiale) Provo a stampare il cubo xyz ed è impossibile Provo a stampare sharebot_filament_glider con i supporti (ho provato a generare gcode con cura a 70mm e 35mm di velocità con i supporti e la stessa procedura con slic3r con il profilo sharebot ufficiale) non stampa bene nemmeno crea strati nell'aria Provo a stampare un marvin per provare a completarlo e vedere ghostering e ottengo una bambola amorfa con molti difetti e non ben rifinita da strato a strato Ho letto in questo forum che ci sono persone che hanno lo stesso marchio di come ho visto le foto sullo schermo e mi chiedo se qualcuno può aiutarmi prima di perdere tutto e venderlo per un miserabile denaro in modo che io possa rimuovere dalle mani il più presto possibile. Post scriptum Il servizio tecnico e di supporto di sharebot mi è stato chiesto mille volte e con mille e-mail non mi hanno mai risposto Apprezzo in anticipo tutto l'aiuto che puoi darmi perché sono disperato, voglio solo stampare le cose, divertirmi ed essere felice Grazie di tutto e mi scuso per il mio italiano, sono spagnolo e mi ha aiutato con il traduttore di Google
